Mustang mspnp2, msd 6al2, no start- but fires
Re: Mustang mspnp2, msd 6al2, no start- but fires
Postby tonawawa » Mon Jun 05, 2017 11:38 am
I think my ignition my be too far advanced.
Do you have an ignition table I could look at, what is the most advanced timing I should run?
Mustang 363, NA.
At 5500-6500 I'm at 30-35degrees advanced. What should be the ceiling?
Car sputters under load at about 6000 rpms.
Thank you.
tonawawa
Postby hybrid » Mon Jun 05, 2017 4:26 pm
That is not over the top, especially if you're at light throttle/cruise.
It also won't cause the stutter you mention - it might cause pre-ignition if it was under load.
On my 347, I have up to 38 degrees timing, although that is at very light throttle cruise 2000-2600 RPM.
Do not load someone elses tune and expect it to work for you!
hybrid
Postby tonawawa » Sun Jun 11, 2017 12:24 am
I idle around 1200-1300 rpm's, Any tricks to get it lower? I raised my timing at idle to get away from the headers getting too hot, its about 19 degrees advanced.
tonawawa
Postby hybrid » Mon Jun 12, 2017 1:45 am
Are you doing idle control?
If not, close the throttle body.
If it's closed, you have an air leak somewhere. Try blocking the PCV if you have one.
hybrid
Postby tonawawa » Mon Jun 12, 2017 5:28 pm
Yes I have idle control, I will try to close the TB a lil bit more.
tonawawa
Postby hybrid » Mon Jun 12, 2017 5:36 pm
What is your target idle set to?
Is it going into closed loop idle?
hybrid
Postby tonawawa » Mon Jun 12, 2017 6:54 pm
Is there a Target Idle number to insert on MS? I have never scene it.
I believe it goes to closed loop, Not sure how to verify that either. WUE and idle duty control both go away near 180 degrees.
tonawawa
Postby hybrid » Mon Jun 12, 2017 8:25 pm
Mate, you really need to read the manuals.
If you have selected closed loop idle, then your idle valve can control idle speed.
If you have selected warmup only, then you will need to use the throttle stop to control idle speed.
hybrid
Postby tonawawa » Mon Jun 12, 2017 10:01 pm
I have open loop selected. I will try messing with the TB next, but I think its almost 100% closed. Thank you!.
tonawawa
Postby tonawawa » Sun Jun 18, 2017 1:45 pm
Here is a datalog of trying to get the car to rev over 7000rpms in my garage. It drops off at 6800rpms on it own.
Can somebody see why?
Thank you.
2017-06-18_13.34.11.msl
(158.77 KiB) Downloaded 6 times
2017-06-18_13.33.58.msl
(34.37 KiB) Downloaded 6 times
tonawawa
Postby Blown88GT » Mon Jun 19, 2017 2:41 pm
tonawawa wrote:Here is a datalog of trying to get the car to rev over 7000rpms in my garage. It drops off at 6800rpms on it own.
Thank you.
7000rpms in my garage???!!!
You killed the engine.
1988 Mustang GT, 57k miles, Orig. Owner
ProCharger 600B I/C, 12psi, FRPP Hdrs, Flwmstr F2, 3G Alt, Mk8 Fan & DCC, 3.55's, Prog Sprng, Subfrms, UCA, LCA, FCA, Tokico 5-way, CSA 16x8, Bridgestone RE760 225/50R16, Crane HI-6, Kirban FPR, MS2, DIYPNPF60, LC2, C&L76mm blo-thru MAF, 30lb FRPP
Blown88GT
Postby Raymond_B » Mon Jun 19, 2017 4:04 pm
Free revving to 7k in your garage, that's crazy. Poor motor...
1995 Ford Lightning. Dart based 427 Windsor, Novi 2000, full sequential, E-85, etc. MS3/3X
Friends don't let friends share tunes...
http://www.buildpics.org/
Raymond_B
Postby tonawawa » Mon Jun 19, 2017 5:05 pm
Its not killed. still alive.
tonawawa
Postby tonawawa » Thu Jun 29, 2017 8:09 pm
Mustang guys, Relocate your TFI if you haven't already. I believe my MSD was getting heat soaked. Replaced with a Ford Motorsports, relocated behind the radiator. So far big difference, yet to see the quarter mile though...
tonawawa
Postby rickb794 » Thu Jun 29, 2017 8:56 pm
If you want accurate spark at 7000 rpm you need a crank trigger,
not a wobbly ass distributor.
This is my brain on MegaSquirt!
Use only these manuals http://www.msextra.com/manuals/
Avoid the common pitfalls, Read this before start http://www.msextra.com/forums/viewtopic.php?f=101&t=65757
rickb794
Postby tonawawa » Thu Jun 29, 2017 9:12 pm
Mine is not wobbly, but I would like a crank trigger and COP. Where could I get the complete kit for that?
I'm ok keeping the rpm's below 7000 on this build.
tonawawa
Postby panel » Thu Jun 29, 2017 9:19 pm
Have you posted one up yet ?
'65 VW Bus Turbo Subaru powered & MS pix CLICK
Running on MS1 since July 22/05,
MSnSExtra July/06 , EDIS Aug/06,
MS-II(upgrade) July 1/10...now...MS-II Extra(upgrade) Oct 10/10!
Sold it all 3 yrs ago & now getting back into it with a MS2 Extra V3.0 Sept/2016
panel
Previous
Users browsing this forum: No registered users and 5 guests
