any one used vr6 obd2 throttle body?
Postby asumsatlil » Tue Dec 05, 2017 1:13 pm
any one used a vr6 obd2 throttle body with drive by cable, does the tps and pwm idle valve work ok? i beleive it will work, just asking for if anyone has experience in it, before i go ahead and get to work.
heres a previous post i read of people talking about it but no one verifies if it worked ok: viewtopic.php?f=94&t=21765
i also have this pin out for the connector
asumsatlil
Re: any one used vr6 obd2 throttle body?
Postby rickb794 » Tue Dec 05, 2017 1:53 pm
Looks like 2 wire idle control. Does it use PWM?
This is my brain on MegaSquirt!
Use only these manuals http://www.msextra.com/manuals/
Avoid the common pitfalls, Read this before start http://www.msextra.com/forums/viewtopic.php?f=101&t=65757
rickb794
Postby prof315 » Wed Dec 06, 2017 4:38 am
No its a bidirectional DC motor and needs a half bridge circuit to control properly. While you can gain very rough control over it with PWM the results are less than satisfying.
Linfert Performance: Come run up front
92 Corrado 2.0L ABA and Borg Warner EFR 6258 on MS3Pro.
94 Ranger 2.3 Twin Plug on MS2
Support the developers!
prof315
Postby panel » Wed Dec 06, 2017 12:58 pm
Not sure if this guy runs that TB but he has run the OEM ECU from VW for the DBW throttle body and then uses MS for the rest. He might be the one to ask ?
https://www.youtube.com/user/drewhastheinternet
'65 VW Bus Turbo Subaru powered & MS pix CLICK
Running on MS1 since July 22/05,
MSnSExtra July/06 , EDIS Aug/06,
MS-II(upgrade) July 1/10...now...MS-II Extra(upgrade) Oct 10/10!
Sold it all 3 yrs ago & now getting back into it with a MS2 Extra V3.0 Sept/2016
panel
Postby prof315 » Thu Dec 07, 2017 6:08 am
panel wrote:Not sure if this guy runs that TB but he has run the OEM ECU from VW for the DBW throttle body and then uses MS for the rest. He might be the one to ask ?
It's NOT a DBW throttle body it simply has an idle control motor attached to the throttle blade. And trust me I have been doing this for YEARS. This is what you need to build to proper control that style throttle with MS using PWM:
prof315
Postby panel » Thu Dec 07, 2017 1:11 pm
So these are not DBW?
https://youtu.be/8fCR7CZQZxc
panel
Postby Paul_VR6 » Thu Dec 07, 2017 8:25 pm
The 96-99 tb is non dbw but used a servo to control the idle with small throttle plate movements.
I am thinking the stepper output could be made to work with some code changes.
-Paul
1995 GTI VR6 MS3/V3
Paul_VR6
Users browsing this forum: Bing [Bot] and 3 guests
