Nissan Micra CG10DE Trigger problem
Postby 3FUN » Thu Jan 11, 2018 11:37 am
Hello!
Has anyone encounter this kind of CAS pattern. I really need to know what kind of wheel decoder must i use with this.
I have attached an image.
Is it even possible to work with this type of trigger/distributor?
cg10de distributor
3FUN
Re: Nissan Micra CG10DE Trigger problem
Postby rickb794 » Thu Jan 11, 2018 7:04 pm
I may be wrong, but I can't find any info showing that wheel pattern is supported, even on MS3.
Is there anther distributor that fits? Or can you crank trigger it?
The alternative is to modify that shutter to be a "basic trigger" (4 windows)
This is my brain on MegaSquirt!
Use only these manuals http://www.msextra.com/manuals/
Avoid the common pitfalls, Read this before start http://www.msextra.com/forums/viewtopic.php?f=101&t=65757
rickb794
Postby racingmini_mtl » Thu Jan 11, 2018 7:21 pm
That would be a '4+1' wheel pattern and as far as I know there is no support for that type of pattern.
racingmini_mtl
Postby 3FUN » Sat Jan 13, 2018 2:16 am
Seems that i must go with trigger wheel attached to the crank pulley with normal patter 60-2.
3FUN
Postby rickb794 » Sat Jan 13, 2018 3:57 pm
A 36-1 pattern would be favorable as the frequency on a 60 tooth wheel bumps up against the upper limit at high RPM.
rickb794
Postby 3FUN » Sun Jan 14, 2018 9:44 am
I'll do that...thanks
3FUN
Postby rickb794 » Sun Jan 14, 2018 10:50 am
If you're not going to rev the dog doo out of it a 60 tooth will work, in that case use what's handy.
rickb794
Users browsing this forum: Bing [Bot] and 2 guests
