How many engines running on MS2/Extra
Does you engine run?
I have an engine running on MS2/Extra
738
100%
Total votes: 738
tjts1
Re: How many engines running on MS2/Extra
Post by tjts1 »
My MB 190e 2.6 5 speed has been running on MS2 extra for about a month now. Its setup for fuel only for now with an SLC_DIY wide band from 14point7.com, EV6 injectors from a Cadillac Catera and lots of other random junkyard parts. Compared to the stock KE-jet fuel injection it really woke up the engine with excellent fuel economy and drivability. I just have a bunch of tuning to do for PID idle, cold start enrichment etc but even with its rough tune its taken me from Seattle to the Bay Area, Lake Tahoe and LA. The plan is to eventually swap in a low mileage 3.0 or add boost. So far I couldn't be happier with MS2.
http://img.photobucket.com/albums/v242/ ... 1293914245
http://img.photobucket.com/albums/v242/ ... 1293914315
cheers
Justin
vr6 turbo ms2
Post by vr6 turbo ms2 »
im runing ms2 v3 on my vr6turbo
starts and drives /tunies but idiol isnt very unstable 13.5 to 15.2afr
runs wasted spark
larnch control
duel fuel maps
38psi map sensor
at 25psi on 95ron fuel
inovate widebands x2
only problem ive found is im loseing sycro (reason 2) very ramdonly (frustating as i carnt seem to sort this issiuse)
i will add this in the correct foruim, with picture
Fausto
Post by Fausto »
Hi. Today my Citröen ZX Dakar turned on!
I'm using a MS2 V3, full sequential, 160lbs injectors, ethanol and i'm learning a lot!
Cheers!
Citröen ZX Dakar Xu10j4rs, MS2 v3, Extra 3.1.2b, JB's full sequencial, 28lbs inj, Wasted COP, Gasoline;
Jonpro03
Post by Jonpro03 »
Hello! My MS2 V3.0 is currently running a 2005 3.5L V6 from Chevy Malibu in my 1990 Turbo Grand Prix.
Working on getting a LS1 style coil near plug ignition system working on it.
panoramix
Post by panoramix »
1990 Renault Fuego GTA 2.2L on itbs running ms2extra v3.1.0 + edis.
nyabinghi
Post by nyabinghi »
DIYPNP on 1989 Opel Corsa A GSI, with engine swap from 2001 Opel corsa C GSI 16v (Z18XE)
100% stock engine
K&N open filter
Custom exhaust manifold
E85 fuel
Power : 138hp @ 5900rpm
Torque : 18,7mkg @ 4000rpm
Test your car horsepower and acceleration with your Android or iOS phone : PerfExpert
Megasquirt successes :
- Opel Corsa A 2L 16v / MS2 speed-density
- Opel Corsa A 2L 16v GSXR750 ITB / MS2 hybrid alpha-n/speed-density
- Opel Corsa A 1.6L 8V / MS2 alpha-n
- Opel Corsa A 1.8L 16V / DIYPNP speed-density
BenGTT
Post by BenGTT »
panoramix wrote:1990 Renault Fuego GTA 2.2L on itbs running ms2extra v3.1.0 + edis.
Nice car :)
Brian I
Post by Brian I »
I have a engine running on ms2 extra. small chevy 350, four bolt main with relatively low compression at 9.0:1 and a fairly rowdy cam (234deg @.050 lift) hooked to toyota /aisin r150f five speed in a '95 four runner( hilux surf to you outside north america). straight front axle conversion, lifted, dual transfer case and its a daily driver!
running fuel only on 2.1.0 right now. will move to 3.1.0 when i get time. And ignition control here shortly.
Thank you all for great information and the most amazingly feature packed code!
How bad could it be?....
'Squirtin since 2005
andodo
Post by andodo »
Got MS2/Extra 3.1.0 running on my BMW 320i E21. Just upgraded from MS1/Extra three days ago and MS2/Extra runs a whole lot better.
turbo t
Post by turbo t »
Ms2 v3 running vw 2.0 60-2 with vr pick up ford coil pack
plans 636 itbs :mrgreen:
bmbelo
Post by bmbelo »
Hi there. BMW e36 M50B20TU head with M3 ITBs and M50B25 block. Wasted spark, vanos control, Citroen VR sensor with 60-2 wheel etc. MS2 V3 3.1.0. Wonderful thing MS is. Enooormous "thank you" to all who contributed to the success of this project.
Regards from Portugal, Bruno Belo
Those who can do, those who can't talk about it. - Colin Chapman
Max Welton
Post by Max Welton »
1968 Volkwagen type-3 here.
Max
Jamie S
Post by Jamie S »
HI there. Checking In. 2.4L LD9 chevy cavalier turbo 18 PSI, full MS2 extra, wasted spark, 1000 cc low z injectors. Been running extra for a year! Love it !!!!
2.4L 99 turbo cavalier fully supported MS2, 419hp, 70mph tire fire.
Jamie S
Post by Jamie S »
pics
uroaruba
Post by uroaruba »
hi, i have an SR20DET running on MS3X whit sequential fuel and spark (mod CAS wheel)
an CA18DET on MS2extra 60-1 tooth wheel Bosch coil wasted spark
an 4G63 MS2extra wasted spark (mod CAS wheel)
an Dodge Daytona '86 2.5liter Chrysler engine, turbo MS2extra single coil (water injection still to come)
working on a BMW 6cylinder 2.5L MS2extra wasted spark
still to come: RB25DET MS2extra wasted spark (mob CAS wheel),
suzuki baleno 1.8L MS2extra COP sequential spark (mod CAS wheel)
deecee
Post by deecee »
hi, I have BMW E21 320i with M10 turbo engine running MS2 Extra in wasted spark COP and batch fire - I am fully satisfied and car is driving flawlessly
here is one bad mobile shot of engine
and here is one in the motion
Black99rt
Post by Black99rt »
99 Dakota 5.9L R/T
MSIIextra 3.1 fuel/spark in parallel with stock JTEC PCM
Stock harness with AEM patch harness for wiring modifications
All stock sensors shared- only CEL is for open injectors circuits
JTEC runs the transmission/gauges/IAC currently
Find out more info on the crank/cam sensor sharing @ http://www.dakota-durango.com/forum/sho ... hp?t=64214
1999 Dakota 5.9L R/T-
LC-1
HidRo
Post by HidRo »
Mine is running as well:
http://www.youtube.com/watch?v=4UMuK9ztMfc
1986 Volkswagen Golf II with a 1.8T 20V engine from an 1999 Audi A3.
MSExtra 3.1.1
Innovate LC1
Wasted Spark on 4 COP's using 4 BIP's
2 banks of 2 High-Z injectors each
Tacho and boost circuits
Swazy
Post by Swazy »
krisstek wrote:a little peugeot 205 now runs ms2 extra!!!
mi16 engine ,jenwey 42mm individual throttlebody.alfa-n,2 coils wastespark
i spend a lot of time to set up it,accel enricment led flashing....why?bad idle...
modify tps filter,from 50 to 10 and...miracle engine runs perfect!
best ecu,great work.
Could you help me out with your base map as i run same engine? Mine is not running but i use single coil and no itb´s
griffida
Post by griffida »
RV8 with MS2 runnung well.
RV8 5ltr
MS2Extra
TEch Edge o2
