How many engines running on MS2/Extra
Does you engine run?
I have an engine running on MS2/Extra
664
100%
Total votes : 664
Re: How many engines running on MS2/Extra
Postby aa.almeida » Thu Feb 07, 2013 6:23 am
Hello, all. Ive got 2 MS2 engines running. A GM inline 6 4100cc/250cu (only ignition for now) and a Porsche spyder replica with an aircooled VW 2300cc/140 cu. The first uses OEM distributor and the VW uses 36-1 toothed weel. Still a lot to do, but engines are running
aa.almeida
Postby maik21 » Thu Feb 07, 2013 2:00 pm
NISSAN SENTRA 93
sr20de + t28 @ 12psi + watermeth inj.
stock engine.
12.5 et.
maik21
Postby nicktruman » Fri Feb 15, 2013 7:04 am
My scratch built Pagani Zonda R replica with its 4.2l twin t3/4 turbo Audi V8, audi 012x transaxle. The car weighs under 1000kgs and is quite quick. I was running a 5.3l Jag v12 with the same turbos but sadly that engine died.
kind regards
Nick
Twin turbo Audi V8 Zonda inspired thing
nicktruman
Postby neverlift19 » Fri Apr 12, 2013 8:57 am
1992 240sx ka24de t3
880cc pte injectors
single msd coil
ms2 v3.57 using diy 12-1 trigger disc
starts and runs decent, in serious need of tuning but its drives and seems more reliable than the oem ecu(chips are stupid!)
ka24de-t 12-1 diy trigger wheel
880cc
t3/t04e 57 trim 11psi
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby jsl240z » Tue Apr 30, 2013 11:57 pm
71 Datsun 240z
vg30et
holset h1c/hy35 hybrid
450cc inj.
still tuning, pretty happy with ms2 at this point. The car already feels like low 12's shifting at 5k.
jsl240z
Postby Dmn2258 » Thu May 02, 2013 7:38 pm
my 93 miata with a 1.8 engine swap and AE101 Individual Throttle Bodies is running Megasquirt2PNP. Isn't tuned yet but i'll update this later on
Dmn2258
Postby hauen » Sun May 12, 2013 4:54 pm
'61 Ford F-100 Unibody. Stock 292 Y-Block run off of a MSModule.
hauen
Postby Moving_Target » Mon May 13, 2013 11:33 am
1993 BMW 318is with a 5.0L SBF swap underway. It currently turns over and idles with a short twist of the key. Colour me impressed. :D
Update:
Idle video in the garage
http://youtu.be/VbMQl_0u4Mc
Engine specs:
Trickflow StreetHeat H/C/I on a Ford roller block 5.0L swapped into the above BMW and running MS2 Extra 3.2.4
- Tacho output (divide by 2) to control the factory 4cyl tachometer
- IAC2 for electric fan control
-TFI mods for ignition
- Ford 2 wire PWM idle valve
- Ford CLT and IAT sensors for MS2 plus BMW coolant sensor for dash guage
:yeah!:
Last edited by Moving_Target on Fri Sep 27, 2013 9:58 pm, edited 5 times in total.
1993 BMW 318is with a 5.0 SBF TFS H/C/I engine and Tremec T5 transmission aka a BimmerStang
MS2 Extra running batch fire and TFI ignition
Currently solving teething issues and tuning
Moving_Target
Postby aixx » Wed May 22, 2013 12:29 am
1987 Audi 90 Q Typ 89/B3 with ABZ engine from 1997 Audi A8. 100% Original setup, including sensors. Piping after exhaust manifold is custom-made ( 3" Y-pipe, no cats, Simons resonator and then original 2,3 10V muffler)
MS II- Extra 3.57 board. 60-2 trigger, 8x COP wasted spark,Innovate LC-1 Wideband, shift light (straight from PT7), Variable length intake manifold ( with protecting circuit and extra relay from PT6) , Tach from B4 80 working, had to adjust potentiometer at the tach a little bit to get exactly right position on tacho,) idle speed almost alright already using original PWM valve with Closed-loop PWM. Needs also some adjustment in 1500-2500rpm area.
aixx
Postby tonyukjag » Wed May 29, 2013 3:30 pm
1962 Mk 2 Jaguar with an XJ40 3.6 aj6 engine ran well enough to pass the mot but is way too rich.
tonyukjag
Postby maik21 » Wed Jun 12, 2013 7:19 pm
nissan 1990 with ford v8 5.0 swap.
running ms2 v3.0 msextra 3.2.4
maik21
Postby maik21 » Wed Jun 12, 2013 7:25 pm
nissan sentra 1994 with nissan engine v6 vq30dek, coil on plug.
maik21
Postby gofastant » Tue Jun 18, 2013 9:36 am
Just got it on the road. 2.0L 16V, 36-1 wheel mounted on the serp pulley. Wasted spark with EDIS coil.
1990 16V Corrado
MS2extra 3.2.1 code, V3 board
36-1 tooth wheel + wasted spark
36 lb Accel injectors
AEM wideband
gofastant
Postby LilSki » Wed Jul 10, 2013 11:59 am
Figured I would add to this awesome post
I am running MSExtra in my 85 TA. It is a pretty basic setup overall running 3.3 beta 12. it's a Vortec 350 with TPI on top running an LT1 cam w/ 22# injectors. Car runs strong and I have about 10k miles on it since it was first megsquirted. It was originally a carbed 305/T5 car. T5 has bee replaced with a T56. I run dual fans, knock sensing, and reverse lockout all through the megasquirt and the wiring harness I made myself. Looking to paint it this fall.
Picture is a little old as it was taken before I installed serpentine belt setup.
Parked next to my cousins 85 vette.
LilSki
Postby Harek1976 » Fri Jul 19, 2013 12:43 pm
Harek1976
Postby 3gd16 » Thu Aug 08, 2013 8:26 pm
i have a 1984 honda civic running ms2 ver 3 with boost and launch control and fan control and a 1988 dodge raider running ms 2 ver 3 also but using honda distributor and throttle with tps
3gd16
Postby aznmagic » Sat Aug 24, 2013 5:14 am
I have a 1994 RX7
1JZGTE from a Toyota Soarer with a Holset HX35
MS2 V3.0 PCB with Zeal circuit board
Stock crank sensor and rear cam sensor for VR signals
6 BIP373's for wasted spark
http://youtu.be/rf-4jIvnhMg
aznmagic
Postby slyrye » Sun Aug 25, 2013 7:35 pm
I have an R34 RB25DET skyline runnning alpha 14 :D
MSnS'n'4G15
slyrye
Postby slyrye » Sun Aug 25, 2013 7:37 pm
Toyota oldschool SR corolla with 1UZFE V8 lexus ls400 engine, also running on MS2 alpha14 firmware :D
MSnS'n'4G15
slyrye
Postby slyrye » Sun Aug 25, 2013 7:38 pm
Honda civic D16 on MS2 same firmware aswell :D
MSnS'n'4G15
slyrye
PreviousNext
Users browsing this forum: Baidu [Spider], Google [Bot] and 3 guests
