How many engines running on MS2/Extra
Does you engine run?
I have an engine running on MS2/Extra
740
100%
Total votes: 740
shropna
Re: How many engines running on MS2/Extra
Post by shropna »
Hi all.
Zetec 2L, fitted in Lotus7 replica:
http://www.youtube.com/watch?v=xmQT0liPcis
Next step - air intake and camshaft changing...
Reverant
Post by Reverant »
Peter Florance wrote:I just converted a Miata PNP system to MS2Extra 210 beta
Has some sync issues below 800 rpm but other than that, runs great.
I'll scope it when it gets warmer, but owner is delighted.
93 Miata with 96 block & 99 head and intake with T2554 turbo
We're controlling the dual intake runner actuator with an added TIP122.
Create a simple howto and the Miata guys will worship you for all eternity.
Jim
The man behind MS Labs
carannc
Post by carannc »
BMW M20B28 with 274 cam, 6 branch, was running MS2 but have now installed MS2 Extra and finished the hardware changes to give wasted spark, separate tacho out, launch and flatshift. Just been out for a full test drive in the snow and its all good. I used the V3 spark board supplied by Stuart> Many thanks for all the help getting me up and running.
Just need a new Bosch plug for the coil pack and a disabling cct for the clutch switch just in case the switch fails on a stage and its been a great winter project finished in true winter style with a test in the snow. :D
TheSteve
Post by TheSteve »
Add my Toyota 2rz-fe to the list. If anyone needs some base maps or configs let me know.
1990 Nissan 240sx
KA24DET on MS2Extra
richyvrlimited
Post by richyvrlimited »
Add a Mazda BP (w/4G63 CAS) motor too :D
2003 MX5. Coldside MP62
mcm
Post by mcm »
Toyota Pickup 22RE here using toyota's annoying VAST ignition system
nevtiger
Post by nevtiger »
1972 Hillman Avenger Tiger.
Used for Sprints, Hillclimbs and other fun stuff.
Running Microsquirt and Extra 2.1.0p. Tuned using Tuner Studio for Ignition only at the moment.
1620cc Avenger pushrod
1.7" inlet, 1.4" Exhaust,
Group 2 cam (ex works profile) 420 thou lift and 320 degree duration
Twin 40 weber with 32mm chokes
All runs very well and is street drivable.
Very chuffed.
fixmann
Post by fixmann »
hi
My Opel (Vaxhall) Omega 2.0 have been running on MS2extra V2.1.0 the last 3 months with no problems.
I had to upgrade from ms2 v2.89 since i changed my motorhead, and on the new head had no distrubitor(head from a newer engine).
I run 60-2 wheel , wastespark, Fan out, and soon closed loop idle.
With this setup i could remove the old flapstyle MAF-sensor, now the car responds much moore quickly.
Up here in the north of cold Norway we had a couldperiod of -16C, the car started and run like new everyday.
The megasquirt its an emazing unit, great work megasquirt team, :-)
Øyvind
Reverant
Post by Reverant »
Mazda Miata, 2002 1.8 with VVT, running happily on a MicroSquirt module, aka DIYPNP.
Jim
RammosV8
Post by RammosV8 »
CrystalBlue wrote:Mazda Miata, 2002 1.8 with VVT, running happily on a MicroSquirt module, aka DIYPNP.
Jim
CrystalBlue ΠΩΣ ΜΠΟΡΩ ΝΑ ΕΠΙΚΟΙΝΩΝΗΣΩ ΜΑΖΙ ΣΟΥ?
elnoble
Post by elnoble »
24c
Post by 24c »
Thought I'd add my cased MicroSquirt to the list, but only because I stuck a diode on the VR2 ground....VE Tables too rich and work in progress, but well pleased with MS Extra 3.0.3 so far :yeah!:
http://gallery.me.com/mike.crane#100048
Yamaha YZF1000 MSExtra 3.1
Activate
Post by Activate »
Dodge Ram 1500 with a 410 and a kenne Bell supercharger.
MsII with 3.03Q and willing to flash to 3.03R if I have a convertor that works.......
I am running on propane.
Thanks and greetings,
Erik
TurboLag
Post by TurboLag »
1990 BMW 325i, M20B25, DIYPnP running on MSExtra 3.0.3r :D Better idle, better response, and better mpg than the original ecu could :twisted:
1990 BMW 325i - The DIYPnP'd Testbed
1994 Mazda Miata - Long term project
krisstek
Post by krisstek »
two engine:
bmw 320 2000cc 1986 ,6x 36mm throttle body(from bmw k 1000)edis6 ms2 extra 2.0.0
suzuki vitara 1600cc,honda throttle body twin injectors,2 coils waste spark ignition ms2 extra2.1.0+lc1
thanks
kriss,Gorizia,italy
murjam
Post by murjam »
Running MS2-extra on Nissan S13 CA18DET everyday.
* 36-1 crank wheel
* wasted spark, stock COP-s
* using stock sensors; only added GM IAT sensor & wideband O2 sensor
* removed (really no need for these): MAF, injector resistors, CAS, ignitor, NB O2 sensor, ECU (of course) and a ton of stock wiring.
Got it running when I first tried and it's been "a bit" messy under the hood since then (8 months or smth :oops:), but working on it now.
B-lennium
Post by B-lennium »
Volvo B30e 3litre 6 cylinder.
Wasted spark Edis6 coil.
ms2extra 3.03r code.
Volvo 164e 1975 3.0l B30
dirtytorque
Post by dirtytorque »
2.0.1 wasted spark setup on a supercharged 92 VW Corrado 2.0 16v g60.
Very pleased.
roarin_mouse
Post by roarin_mouse »
'79 Camaro
18" wheels
4-wheel disc brakes
ZZ-383 with GMPP Ramjet, 30 pound injectors
700R4 w/locking 2400RPM converter, 3.08:1 rear end
Wasted Spark with 8 LS2 coils
Semi-sequential 36-1 missing tooth wheel and VR sensor
1979 Camaro
383 stroker w/Ramjet EFI manifold
MS2 Extra running semi-sequential, wasted spark
Monzsta
Post by Monzsta »
'97 Chevy Lumina FWD.
3400 V6
MsExtra 3.03r controlling fuel and spark.
The stock pcm is just minding the tranny and gauges now. Awesome driveability, and better power and mileage.
'98 Trans Am LS1 A4
Ms2 3.0 board, controlling fuel and spark.
