How many engines running on MS2/Extra
Does you engine run?
I have an engine running on MS2/Extra
740
100%
Total votes: 740
Joe
Re: How many engines running on MS2/Extra
Post by Joe »
I finally have a V-8 572(720hp) BBC chev running on the latest release code. I have closed loop idle issues but other than that runs good. LS2 coils 60-2 trigger wheel. Very pleased.
Joe-
78 Chev 4x4 MS3. Microsquit 4l80E (Toy Hauler/Beta test rig )
70 AAR Cuda -Hanger queen- 340 MS3 Seq- XV Level II
rickshank
Post by rickshank »
Thanks to PF, my engine now runs using the beta from the end of March 2009.
84 Honda CRX (base model) [originally carbed]
-- 87 CRX SI motor, built 13.5:1, running C12 leaded fuel
-- 60-2 Electromotive wheel + Electromotive 1/2" pickup
-- 4G63 dual coilpacks in wasted spark configuration
bcrx7
Post by bcrx7 »
1991 Ford Escort GT.
Code: v.2.1.0 RC (09.05.05).
Engine: 1995 Mazda 323 1.8L (Overbore 1.91L). VJ23 Turbo running at 25PSI.
MS3 board with the diyautotune.com Map Daddy 4 bar sensor.
Miata CAS (4/2 same as 4G63), Two RX-7 Primary Coils running in wasted spark mode ignited by Bosch BIP373's.
Controlling Stock PWM Idle valve and a GM Boost controller valve.
Previously on MS1/extra HR 10g for a couple of years and others codes before that.
1984 Mazda RX-7 GTM Class (BP Engine + BW-EFR 8374 Turbo Full COP/Sequential on MS3+MS3x)
1986 Toyota 4Runner (22RE running on MS2-Extra 3.2.1)
SQLGUY
Post by SQLGUY »
1982 Yamaha Seca 750
Engine: 748cc inline four, air cooled
Microsquirt with MS2/Extra 2.1 beta
Port injection with Hyundai Accent injectors and pressure regulator, custom fuel rail and manifold
Bosch/Saab fuel pump in tank
1997 Ford Escort throttle body with PWM IAC
ECU is also running GM Saturn coils in place of stock Hitachi coils (better spark and better wires)
Custom 36-1 crank wheel for timing
Project page: http://residentialcolorado.com/SECA_750i.htm
Peras
Post by Peras »
Mitsubishi 3000GT twinturbo 3.0 V6
Running MS2 Extra RC 2.1.0n
Stock coils and ignition module, using ground switching for firing coils, wasted spark mode
Stock cam and crank sensors - Thanks for this wheel decoder, made my life easier :D
Innovate LC-1 WB O2 controller
Car is running great, only IAC stepper is not working yet
When in doubt, flat out...
prof315
Post by prof315 »
I've now got 4 VW's going on MS2/extra 2.01 code. 2 SCCA GTL Sciroccos with counterflow heads (1 1.6L and 1 1.8L) Waste spark and LT1 throttle bodies. 2 SCCA ITB cars 1 95 Jetta and a 96 Golf Both ABA 2.0L cars with single direct coil control VERY VERY happy and car #5 comes this week for it's install an 89 Accord Lxi
Support the developers!
supermac
Post by supermac »
I have two at the same time!
Twin 350 chevys running TPI injection on my 1978 33' Carver Mariner Yacht. Finally the IAC's are working in closed loop and working great on 2.1.0.
Thats an awful lot of fun for the summer.
msoultan
Post by msoultan »
...and where are the pictures of the engines?! :D
tcoleman8851
Post by tcoleman8851 »
i have a 1990 Saab 900SPG drag car that i just got MSnS extra up and running on
V2.2 running EDIS coil pack and VR sensor, MS waste spark mode, holset Hy35, quick little car,, haven't raced it yet that will come this summer
Keithg
Post by Keithg »
tcoleman8851 wrote:i have a 1990 Saab 900SPG drag car that i just got MSnS extra up and running on
congrats and careful on the tranny. I daily drive my '91 SPG and hope it lasts a while.
KeithG
toplessFC3Sman
Post by toplessFC3Sman »
I've got a 1988 Mazda RX-7 Turbo that i'm running MS2/E 2.1. She's being mostly used for auto-x and cruising, and I'm currently working on getting CL boost control working properly.
Spinning Doritos on a stick
supermac
Post by supermac »
Better than pictures, I have video! :yeah!: The engines are idling but I need some better video editing software that will let me mix in the music with the sweet idle sound of through the hull exhaust!
http://www.youtube.com/watch?v=t942RROR1NI
dropthattaco
Post by dropthattaco »
Well, add me to the list!! 1997 Toyota Tacoma 2rz. Home built turbo running just less than 300 hp and 330 tq (dyno proven). Built for plug and play, it plugs into the OEM computer harness. Just switched over to MS2/x 2.1.0 a couple of days ago, and after stumbling through a few config changes, she's running smooth as silk. RIGHT ON FELLAS!!!
sprint_turbo1
Post by sprint_turbo1 »
Been running MS2 extra 2.0.1 code for last 6months, still tuning!
Have a Triumph dolomite sprint 16v engine fitted in Triumph spitfire 1500. Running fuel and spark via edis4 and 36-1 wheel. Garrett T3 and 10psi boost. Had some good fun so far started with MS1 fuel only a couple of years ago. Decided to upgrade for better performance and control on ignition.
Certainly makes some of these modern cars wonder what the hell pasted them!!!
ianferrell
Post by ianferrell »
1988 Mazda RX7 with mild ford 5.0 (340-350hp est)
91 tbird short block, .030 over, windage tray
Gt40X al heads (64cc chambers I believe, haven't measured), 1.7 crane 'cobra' pedestal roller rockers.
E303 Cam, wrapped bbk shorties and duals w/ h pipe (converted from a mustang, lol)
5.0 explorer intake (gt40 cobra style), 'terminator' injectors (39 lb, 03-04 cobra)
5.0 explorer fuel rails, (wanted to be able to go flex fuel hence the bigass injectors, but I think the rails will hold me back)
mallory max fire distributor
(I've recently converted from carb, eventually will install exploder timing cover because it uses the same pattern of water pump, and has the bosses to run a crank sensor, I already have a explorer 36-1 toothed balancer)
'z spec' t-5 trans, GTU LSD rear end and '5 lug' conversion (turbo 2 brakes more significantly)
Oh... and of course It rolls on 99-04 mustang gt 17x8s, with the pony center caps for the lol factor)
Runs pretty well, definitely better than the carb, but I lost my heater core and AC in the process of putting all the EFI stuff on there... projects like this are never done. Can't keep the idle steady, need to read about alpha N as E303 only pulls about 16inHg at idle)
linuxman51
Post by linuxman51 »
The volvo has been running ms2-e for about a year now, maybe longer.
512 rwhp through a stock automatic (briefly, at least :lol: )
and 10.8@129mph, same setup.
12 years of ms-ing things up..
607whp volvo 740 (ms3pro)
1994 volvo 940 turbo L33+7875+ms3x
knightrous
Post by knightrous »
89 Toyota MR2 AW11
Stock 16V 4AGE using stock VAST ignition
MegaSquirt2 v3.0 + MS2Extra 2.1.0
'89 Toyota MR2 AW11 - 1MZFE 3L V6 - Need to finish car before ecu :(
'89 Toyota MR2 AW11 - 16V 4AGZE - DIYPNP 1.5v
'90 Toyota MR2 SW20 - 1MZFE 3L V6 - MS3X
radics1
Post by radics1 »
Audi A4 1.8T MS2 extra V3 Wasted spark COP,boost control,launch controll. 40000km and still no problem :D
Audi A8 1.8T AEB, Paralel ecu for A/C,MS2 V3 on 2.1.0 Code,Boost,launch,Fuel&spark,etc..
Fiat X1/9 1.6 turbo MS2 extra V3
Hungary,Lake Balaton
mariob
Post by mariob »
Peugeot 106, 1124cm³, stock 60-2 wheel, stock wasted-sparc-coils, JAW Wideband, MS1/Extra HR_10g since 03/2009, MS2/Extra 2.1.1b since 11/2009, ~100hp@~8000rpms
This is my daily-driver and at the moment it is running with a fixed idle, which is not very useful in the morning but still easier than living with a 25% overclocked stock-ECU :P
Regards, Mario
Peugeot 106 Sergio_Tacchini, 1124cm³, MS2/Extra pre3.3alpah15, E85
Citroen AX, 954cm³, MS2/Extra pre3.3alpha15, E85
Peugeot 106 Rallye, 1298cm³ ... waiting for ITBs and full sequential injection
BLOZ UP
Post by BLOZ UP »
1988 Z31 Turbo
3.0L VG30ET
MS2 Extra 2.0 triggered by stock Nissan CAS, with LC-1.
Works great. Need to dyno tune. Second Z31 I've megasquirted. First one had MSnS
