How many engines running on MS2/Extra
Does you engine run?
I have an engine running on MS2/Extra
738
100%
Total votes: 738
D Knapp
Re: How many engines running on MS2/Extra
Post by D Knapp »
Hi,Have a 89 Mazda f2T Runnig on Mse2.01in V3 Bd,Ford edis4 ign(complete with module)stock turbo,injectors,Saab intercooler,no boost yet Runs sweet,driven about 15 miles needs more tuning :yeah!: By the way all the above is in a '90 cab plus Mazda P.U.,5 spd. man.with ps,ac and cruise(packed engine comp)D.Knapp
Keithg
Post by Keithg »
I won't vote again, even though I am in Chicago ;-)
I have been running it for at least a year and a half on my Saab.
1991 Saab C900 SPG
2.0L turbo
Tach out
PWM closed lop idle
Added DI cassette with 'time after spark' ignition.
Required 36-1 pattern machined into back of flywheel and 1 per rev cam sensor
both wheels hall sensed
KeithG
Buick_powa
Post by Buick_powa »
Running yeah but not at his best!
Buick 3300 V6
MS-II/Extra
C3I Ignition setup
Stock sensors/injectors
jsbuggy1
Post by jsbuggy1 »
I set it up on the stimulator, flashed to my vehicle and it worked perfect. Messing around with the closed loop idle control and then I am done. Kinda stinks cause I am having fun. :D
I actually have MSII Extra running on 3 vehicles and Microsquirt on an outboard engine.
RangingRover
Post by RangingRover »
Another one here:
Alfa 164 3.0 V6 (quadcam 24v) retrofitted into an Alfetta GTV.
Wasted spark, using standard Modules/coils, and standard crank sensor with its 60-2 wheel, GSX-R750 ITBS.
Yet to be tuned fully, but definitely melts tyres well.
4.6 V8 '84 Range Rover, MS1 V3.0 on extra - Fuel and Dizzy Spark.
'81 Alfa Romeo Alfetta GTV - Was 2.0 4cyl MS1extra V3.0 + GSXr-750 ITBs, Now 3.0 quadcam V6, wasted spark, MS2 extra, GSXr-750 ITBs. I swear I had tyres on those rims when I left home officer....
evo828
Post by evo828 »
Landrover Discovery I 3.9 V8 with Auto gearbox
MSII/Extra r .2.0.1; EDIS8, WB LC-1
basically it is drivable; still playing with IAC stepper and will start VE and Ign tables tuning soon
1998 Landrover Discovery I V8 3.9, MSII/E ver RC 2.1.0 20090505; EDIS8; wideband LC-1
chips60bug
Post by chips60bug »
I have a 1960 VW bug, running MS2 extra w/flex fuel, and wasted spark. Its in the tuning stages right now. Very impressed! Turbo coming soon!
Chip
65looter
Post by 65looter »
342 Ford with a Microsquirt and MS2 Extra code
Ford 342 stroker | 4inj.TBI
MS2/Extra beta RC3 2.1.0 20090611
sadmind
Post by sadmind »
200sx s14 sr20det Running on MS2 Extra
Stock CAS with modified wheel 36-1 holes
Hyundai Coil with Primera GT Cables
running wasted spark on ~1bar boost
still few problems but running! :)
Changed the CAM sensor and wheel due to lost sync problems, now with the 36-1 crank wheel and Golf3 ABF crank position sensor its better, still some strange problems when release the gas pedal, but at all, better than before ;)
FSG_PB_Patrick
Post by FSG_PB_Patrick »
Modded our 2008 FS Car towards MS2, swapped sparks around 360deg, made it start and suffer from really bad noise issues. How I hate VR Sensors! :?
Last edited by FSG_PB_Patrick on Tue Feb 17, 2009 9:00 am, edited 1 time in total.
Patrick
Formula Student Cars MS1/MS2:
Suzuki SV650S, Suzuki GSR600K3,
http://msruns.com/viewtopic.php?f=93&t=22782
Projects:
Nissan Primera P11 with SR20DE (SR20VE 20V) MS2
Peter Florance
Post by Peter Florance »
I just converted a Miata PNP system to MS2Extra 210 beta
Has some sync issues below 800 rpm but other than that, runs great.
I'll scope it when it gets warmer, but owner is delighted.
93 Miata with 96 block & 99 head and intake with T2554 turbo
We're controlling the dual intake runner actuator with an added TIP122.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
myk777
Post by myk777 »
My ATV is running MS2E 2.01 (fuel only for now)
Yamaha YFZ450 single cylinder 450cc ~50hp
Single hall sensor on a missing tooth cam wheel 24-1
Revs to about 12,000rpms
Since it is a single cylinder and I'm now using the cam wheel it is running synchronous, this has enabled me have the map reading in the same point in the cylce every time and for the first time I am sucessfully running speed density on this motor which has an extremely short intake and wild camshafts.
Here's some pics of the setup, this was back when I was running the B&G code.
http://www.msefi.com/viewtopic.php?f=89&t=33122
Mike
FSG_PB_Patrick
Sorted out my issues on the GSR600 from a week ago. Success may be a function of work and pain, at least it backfired right beneath my hand (ouch!) and bitched around until today. But thats all forgiven since it runs :yeah!:
Patrick
Projects:
Rhdhybrid
Post by Rhdhybrid »
2000 Honda Civic
CR/Vtec - M62 Supercharger
Ms2 Extra 2.0.1
Launch/ Flatshift plus Vtec on IAC
Runs like a champ all last summer, 20,000kms. Into a rebuild and upgrade there now, so it is down for now..... Can't wait for the snow to go.....
93 Skyline GTR
2001 NUR Spec Powertrain Swap
Way to many upgrades to list.
2.0 CR/Vtec - Long Gone..... Great Learning Experience.
B20Z Block, B16a Head(Big Valves- Ported)
Supercharged
Megasquirt 2 V3.0 With 4 Bip 373s running Wasted Spark.
01 CBR 929RR Coil Sticks
Bimmerjim®
Post by Bimmerjim® »
just got mine running two days ago. :D still working some bugs out tho..
1989 BMW 325i + GT3582Rle turbo.
MSII V3, 36-1 wheel, VR input.
running 3 coil drivers and wasted spark, ms2 extra 2.0.1.
still yet to connect the tach out, boost control, fan control, idle control and launch control.
:yeah!:
1989 BMW 325i, custom fab turbo.
V3 MS2 extra, 36-1 wheel + VR, Ind coil control/Wasted spark, IC, BC, FC, LC.
MSI Wind, Win XP, 10", 1.6 ghz, 2gb ram (2.3 lbs) + usb to db9
65looter
Post by 65looter »
I'm back on the extra code now, the normal code 2.888a was giving me trouble with rpms stuck at 1500/2000
olivier16s
Post by olivier16s »
after 6 months.... it is running well.
Renault clio 16s (Gr N)
44-2-2 MSII V3 VR input
Ms extra beta 20090327
Original single coil + distributor
Original low Z injection
Original Map sensor
Original TPS + PWm idle.
Just some little bugs to fix (stable idle, tps enrichisment)
Specially thanks to Terrastudios and jscortina .
oliv
Renault Clio 16s 1992__________Renault 5 gt turbo 1985__________Alpine GTA V6
1980cc 4cyl, single coil , high Z___1393cc 4cyl wasted coil, low Z ___2800cc, 6cyl
206 hp @ 7100 tr/min__________180hp @ 6000tr/min____________180ch@6300tr/min
landybehr
Post by landybehr »
turned to 2.1.0 beta a few weeks before. I was happy with the B&G code but the extra-code seems to come out on top with tuneability and stepper action and it has all options I could ever need for my old fashioned V8. I have not yet played with closed loop idle, first everything should be fine without it and then it will be allowed to counteract the revs dropping when shifting from "N" to "D".
Had slight but very bad feeling problem with TPSdot (acc enrichment kicking in and) spoiling the idle and giving me a badly shaking engine after downloading the extra firmware. After an hour of desperation that´s been sorted by the threshold. Other very minor issues but they were gone once all the obvious variables were dialed in. MAT correction was worthwile to deal with.
Great piece of work that code - somehow I feel it´s harder work to do than making a code for a specific car because there are so many ignition options to be chosen from and so many different setups that need to be cared for. So BIG thanks to those you did the hard work, countless hours behind the keyboard, bearing foolish questions (most of them from me) in the forum i.e James, Ken, Philip, ..
4.2l Rover V8, automatic transmission
2.1.0 beta 20090311
Stepper IAC
Range Rover Classic
enginesong
Post by enginesong »
Just finished wiring my '95 Talon a few days ago, updated to MS2E (beta 2.1.0 20090327) and it started on the first try!
1995 4G63T (2.0L turbo)
- Wasted Spark - original coils and original ignitor.
- Shared coolant sensor.
- Shared TPS.
- Using a 1g green-top CAS with a custom 24/1 wheel (vs 4/2).
- Factory ECM still picks up original 2g CAS for control of dash tach.
'90 Supercharged Isuzu Amigo, 4ZE1 (MSII v3.0, B&G MS2 code v2.881 w/EDIS4) - on the road since April 2007.
'95 Talon TSi AWD, 4G63 (MS2E beta 2.1.0 20090327) - on the road since June 2009.
e30eric
Post by e30eric »
Been running MS2/EXTRA on my 1988 BMW 325 2.7 for a year now.
288 Schrick cam
Super ETA bottem end
885 Head
GM DIS Coils for Wasted Spark
Seattle WA.
