How many engines running on MS2/Extra
Does you engine run?
I have an engine running on MS2/Extra
738
100%
Total votes: 738
gravie
Re: How many engines running on MS2/Extra
Post by gravie »
vw beetle with typ 4 2400cc engine
v3 board
ms2 extra 2.01
330cc SAAB turbo injectors
36:1 trigger with vr sensor
bosch wasted spark coil (opel1208065 / GM90443900 or the same as bosch motorsport 0221503001 ) with bosch ignition modul 0227100200 /BIM200 in place of two vb921 >very easy to install :yeah!:
innovate lc-1
reckless
Post by reckless »
'91 saab 900 turbo 16S ( would be SPG in US )
1995cc i4 16v
v3 board
ms2 extra 2.0.1
440cc lucas injectors
bosch 137 ignition module, triggered from stock dizzy ( moving to EDIS )
Innovate WB
I converted from MS1-extra, and the main improvement so far is smoothness. AFR's rock steady with the simple proportional WB control. Hopefully running boost control later today, 2 wire idle control soon after that.
DaandeRoos
Post by DaandeRoos »
Jetstar boat with Ford Essex 3.0 V6 engine
Custom made inlet manifold
19 lb bosch injectors
Ford double 48 mm throttle body
Walbro fuel pump
Ford edis6 coil pack controlled by MSII extra with VB921 wasted spark
36-1 trigger wheel
krazydriver
Post by krazydriver »
i've been sucessfully running megasquirt on my 1993 240sx for 4 months/1000 miles so far.
Ms2 v3.0 pcb, 2.01 release firmware as a full standalone.
Ka24de with a t3/to4e turbo @ 7psi.
555cc injectors, walbro 255, Swapped cams, 3" turbo back.
street tuned myself with an LC-1 and Knocksense.
Car runs awesome, still need an actual dyno run though.
TheRealNap0le0n
Post by TheRealNap0le0n »
Got em
Engine:.040 overbore, Hugger Orange Paint Mod(lol), Moroso Deep Sump 7 qt oil pan w/ crank scraper and windage tray, 2 piece timing cover
Tranny:Factory T5 grenade ( pin pulled )
Ignition:Summit CC distributer ( 8 Pin HEI )
Air/Fuel:HSR controlled by MS 3.0 (on Extra Code 2.0.2), Holley Systemaxx II heads, Cam motion custom grind (224, 234 duration) cam
Headers:Hooker supercomp 1 3/4"
Exhaust:custom 2.5in true dual exhaust, Flowmaster 40s, 3" Tips
mrchaz
Post by mrchaz »
Vauxhall C30SE 24v straight 6
Mantzel 4.0L conversion
Calibre Turbo injectors
Zeitronix Wideband Lambda
Ported head
Wasted spark using Omega coil pack
Dangerousdave1972
Post by Dangerousdave1972 »
I've been running my VW camper with a 2.4L 6 cylinder Chevy Corvair engine for well over a year now. Only got a problem with the sparks now.
VW Camper, Chevy Corvair 2.4l engine
Ford coil pack
V3 board with 3 coil drivers
LC1 wideband
36-1 trigger wheel.
Dave
Nolat
Post by Nolat »
87 MR2 supercharged
4AGZE 1.6L
EDIS-4 (with 36-1 wheel)
Stock 365cc injectors
180mm crank pulley (12psi)
LC-1 Wideband
V3 board
Colt
Post by Colt »
Got mine running on MS2/Extra 2.01 today.. Was a rough start, because of a few oversights, but overall it was as simple
as loading the firmware, getting everything configured right and tuning it out.. I made no hardware changes at all.
79 Mustang, Ford 302 ( bone stock I might add, has 60 1/4 mile passes on it ),
with the exception of the Vic JR intake manifold,
and long tube headers ), 150 shot of nitrous
TFI ignition, but only using the Hall sensor for signal, set to Basic trigger.
Driving the igntion coil with a bosch driver ( BIP373 ), using JS10 for the
output. Though I will probably change the port soon after I'm comfortable
with how MS is working with the Extra code..
Closed loop idle control, though not yet fine tuned.
Also have a 2 step setup and working, but have yet to wire up a launch control circuit.
Might be wired off the line lock, or maybe the clutch switch..
Been running MS2 B&G 2.88 for over a yr, swapped over to
Extra for the upcoming turbo setup in a week or two.
Will be a 70MM single turbo setup.
I plan to run boost control with MS2.
We'll see how it goes, but so far I'm thrilled with the firmware..
Last trip to the track in the car, it ran a 12.5 @ 111 MPH, spinning through 2nd gear,
running 26X10.5 MT ET street radial's, 5 speed tranny, with a '04 Cobra IRS rearend built to handle 900 HP..
Car is track only at this point, but will be street driven from time to time next yr..
M52 POWER!
Post by M52 POWER! »
My car runs on MS2 but it doesn't run as smooth as I'd like it to :oops:
OliveRS
Post by OliveRS »
VW aircooled turbo beetle running MS2 Extra2 on V3.0 pcb
- T03/T04 turbo @16psi
- 650 cc RC injectors High imp.
- Bosch fuel pump
- Jenvey TPS on IDA flange home made throttles bodies 48mm bore
- MSD 8485 dizzy locked with VR sensor
- MSD6A CDI
Racing use only .
Challenge everything
terotin
Post by terotin »
Been running all summer (6 races + shows) on my friends drifting-car.
http://www.x-treme.fi/albums/album185/W ... eme_51.jpg
http://www.x-treme.fi/albums/album177/IMG_0098.jpg
- Nissan 180SX with BMW 745 engine, 3.2litre turbo (ol-skool)
- MS2-extra 2.0rc1b, v3 board.
- 60-2 original BMW-trigger
- Ford 6-cyl wasted spark coil
- 630cc Siemens Deka injectors
- Dynoed (with bad spark plugs, little misfire) 410hp, 520Nm.
Runs perfectly. We expect it to run equally, when base engine is going to be swapped to a M5 6-cyl.
pb3
Post by pb3 »
I am pleased to now be able to add my self to this list. Somehow I went over two years only running the standard B&G code on my MSII and felt I was missing some features, glad to discover the Extra code leaving me nothing to do but re-flash etc.
Started the car up last night without any issues, other than it seemed to be leaner on warm-up. I did modify the code slightly so as to allow me to run single stage nitrous using the FIdle (spare) output. I added two switch to battery inputs on my V3 board so will be making use of the Launch and Flat Throttle Shifting features as well. Now all I need to do it get the d*** clutch switch installed, that is proving the hardest part of the whole operation!
Happy motoring...
Edited to add: Just noticed my footer note, must change that ;)
________
Ultima GTR Small Block Chevy 6.3L (383cu in.) / MS-II / v3.0 (With Extra inputs) / MS2Extra 2.1.0 (Modified launch control) / MT 2.25
Innovate LC-1 / GM IAC / EDIS-8
http://www.msruns.com/viewtopic.php?f=97&t=18548
duckzito
Post by duckzito »
VW Gol AB9 running MS2 Extra2.0.1 on V3.0 pcb
- 1.8L Engine
- T03/T04 turbo @15psi
- 570 cc Siemens injectors Low Z.
- FMIC
- Bosch fuel pump
- Hall Sensor, STD Coil
- LC1 wideband
justins71
Post by justins71 »
95 eclipse GS
420a chrysler 2.0L
8.8 dish pistons
50 lb/hr Holley injectors
port/polish head, std valves yet...
3" custom DP/cat, 3" PIT cat-back
t3/t4 turbo, 15 psi (for now, until it's retuned, then back up to 18)
FMIC, 2.25" piping
V3 board MS2 extra (RS-autosport MS1 w/ MS2 daughterboard upgrade), fuel & spark
'95 Eclipse 420a
MS2-Extra Fuel & Spark
t3/t4b 16psi
otis
Post by otis »
-85 BMW E30 with M30 swap, MSII extra V3.0 w/EDIS6
-85# injectors
- Holset HX40
-16psi
-No traction :lol:
Turbo 2.0 BMW
323rwhp 15 psi
MSII EDIS4
severnrc
Post by severnrc »
just got my 84 BMW 318i E30 running today!
Running mostly stock engine for now with MS Extra 2.01 code on the V3 board (turbo to come shortly)
CAT IMAT sensor
Stock coolant sensor (if anyone has the real thermistor transfer function please share the info!)
Ford Explorer 4.0L 65mm throttle body
Ford EDIS 4
Ford IAC - closed loop (still needs fine tuned)
30 lb/hr reman injectors
wasted spark
still need to wire the tach up to the dash, but can't wait to see what kind of fuel economy I can get :)
Nutzy
Post by Nutzy »
BMW E30 with M20B27 2.7 liter six
9.6:1 comp
Garrett -0032 GT2871R, LPG only
GM waste spark coil pack
60-2 VR
External Bosch twin channel coil igniters
Ford 65mm TB
Stock coolant sensor, GM AT sensor
launch control
Closed loop idle control to come
JS10 running stock tach
http://www.youtube.com/watch?v=MpQod0WdtmU
N
Black99rt
Post by Black99rt »
99 Dakota R/T 5.9L
KenneBell 2.2L S/C with Snow water/meth
65lb F.A.S.T. Low-Z injectors
255 Walbro Intank
MSII v3.0 board, Relay Board, MSIIExtra2.0.1 fuel only
Tach-in from MSD6al Tach-out
Sharing temp sensors
JAW1.03 WB outputting 1-2v 10-20AFR
Factory computer controlling timing, IAC and transmission
The truck is running on MSIIExtra, just not driving yet, it fired up straight away with the initial settings(thanks guys!). Still need to do a lot more tuning.
1999 Dakota 5.9L R/T-
LC-1
Coggin
Post by Coggin »
'84 Volvo 242 Turbo running on MS2 Extra v2.1 beta
- Rebuilt '93 B230FT squirter block and head with tight squish at .030"
- 5 speed
- 36lb Lo-Z injectors
- 15g turbo
- Late Volvo intercooler
- 12 psi currently (clutch won't hold more)
- 3" exhaust, no cat
- 255 lph in-tank Walbro
MS-wise:
- MS 2 Extra v2.1 beta V3 board
- EDIS 4
- Boost control with the GM valve
- PWM Closed loop idle with Bosch 2 wire valve
- Knocksense
- e-fan control
- Innovate LC-1
- GM IAT sensor, factor CLT temp sensor
Project thread: http://forums.turbobricks.com/showthread.php?t=99500
Jay
84 Volvo 242 turbo- Rebuilt B230FT, 15G, MS-2 extra, EDIS
