How many engines running on MS2/Extra
Does you engine run?
I have an engine running on MS2/Extra
738
100%
Total votes: 738
slyrye
Re: How many engines running on MS2/Extra
Post by slyrye »
MR2 3SGTE with MS2 on beta13 firmware :D
MSnS'n'4G15
PJF
Post by PJF »
Chevy 5.3L LS running on MS2 with V3.2.4 code. 24 Tooth reluctor wheel, wasted spark, batch fuel, and 70MM turbo in a 1986 Monte Carlo SS. This thing runs STRONG!!!
The MS2 and relay board that is mounted under the drivers seat. The yellow arrow is pointing to the jumper I installed to make the tachometer output on the FIDLE pin work.
A view under the hood showing the LS and the T4 turbo attached to it.
And finally here she is out adding some pollution to the environment. :D
The MS2 rocks, I am so happy with it!
huafist
Post by huafist »
I had a twin turbo mustang running on MS2 before it put it in the wall lol
I have megasquirted multiple vehicles in the area however, including:
Turbo ford probe - ms2extra, 250hp, 250ft/lbs tq on 6psi
1988 Starion - ms2extra, 280hp, 370ft/lbs tq
Fox mustang w/stroker - ms2extra, DIYPNP, 626hp, unknown tq(wheels spun on the rollers)
Just finishing a 1995 240sx w/RB25 swap, LS1 coils, banks stg2 turbo, etc, and just got a base map rolling on a supercharge 310ci fox mustang.
maik21
Post by maik21 »
FORD TAURUS SHO (yamaha engine 3.2L 24v)
ms2 extra 2.4.5
oem ford coilpack and 3 nissan ignitor modules.
36-1 wheel with allegro 627 sensor.
turbo 70mm.
300whp.
78turbobird
Post by 78turbobird »
1978 formula firebird. twin turbo sbc, ms2extra 3.2.5, megashift 4.130 connected to 4l80.
wasted spark with 60-2 wheel
engine running great but cant get much further till gpio communications fixed.
fast930
Post by fast930 »
after months of tuning and hair loss my 87 porsche 930 is ptting down 602 rwhp on ms2 at 21 lbs boost. motor is coming out for bigger cams and i will be switching to ms3 and i guess loose more hair but am shooting for around 700 hps at the wheels. try to do that on old cis outdated crap!!!!!! just wish it had a better name. the big tuner guys are snubbing their noses at me (until i blow past em) keep up the great work guys this stuff is awesome
Bzltyr
Post by Bzltyr »
I am driving it every day.
1976 Pontiac Ventura
Olds V-8
7 pin HEI
GM TBI from S-10
MS-II extra
LC-1 wideband
Thanks to all those who have helped me get it going.
I still need some tuning but it is working.
Bzltyr
Post by Bzltyr »
Well, it was running.
hang 4
Post by hang 4 »
1980 Porsche 911 with MS2 and EDIS.. Started with MS1, fuel only and have been tinkering for the last 5 years. Finally feel like it's close enough to make it worthwhile going to the Dyno....
JPSeuropa
Post by JPSeuropa »
2 cars running.
Lotus Europa Twin Cam
and a 4AGE 20V in a Locost 7
Contos
Post by Contos »
86 Mitsubushi Starion Running on fuel only for 2 years best pass in the 1\8th was a 8.77 @90 just installed an edis-4 but can not get it to advance
Also a Mazda B2000 running ms1 with ITBs fuel only as well
grom_e30
Post by grom_e30 »
1999 gsxr 600 srad originaly carbed, with microsquirt v3, 2007 gsxr1000 24-2 timing rotor, 2002 gsxr dumb coils fired in waisted spark from a bosch 211 ignition amp, 2004 yamaha r6 throttle body's, innovate wide band, bosch water and air temp sensors and a 2.5 bar saab / gm map sensor. up and running but a long way to go yet
Nagtrainer
Post by Nagtrainer »
Mine is an '86 Suzuki Samurai, with a 2000 Swift G13BB. The engine is a mild build with GSX1100 pistons and 242@.050 lift. Nothing else real super duper, Running a Micro V3 with the MSExtra Coad. 36-2-2-2.
garsten
Post by garsten »
1968 Ford F100, 521 ci BBF. 2 wheel drive short bed.
68 F100, 521 ci BBF. MS-II V3.57 PNP for 86 - 93 Ford 5.0, using TunerStudio MS Registered, Zeitronix ZT-3 Wideband.
81 Ford Fairmont, 347 ci SBF, Accufab 4-barrel TB, GM IAC Stepper, 42# injectors, PLX Devices Wideband, Powerglide, MS3X, race only.
bmwcapri
Post by bmwcapri »
1981 Ford Capri Calypso with 1994 BMW M60B40 V8
Microsquirt V2, EDIS-8 ignition module, 36-1 trigger wheel, ford escort coil packs
All original BMW sensors - VR, PWM idle, IAT, CLT, TPS
Story of a microsquirted BMW V8 in a ford Capri - http://www.bmwv8capri.yolasite.com
E36Turbo
Post by E36Turbo »
bmwcapri wrote:1981 Ford Capri Calypso with 1994 BMW M60B40 V8
Sick car!
Tony Evo
Post by Tony Evo »
Lancia Delta Evoluzione 1991
Vortec350s10
Post by Vortec350s10 »
1986 Honda CRX si. 1.5L 12V stock engine. Running a MS2 3.0. Fuel and spark using all Honda sensors and stock distributor and coil. Just wired and installed the stock PWM idle valve tonight. Did the pwm mod with the upgraded transistor. Seems to work great in testing. Ran it N/A all last summer and added a turbo among other related upgrades to the stock engine. Can't wait to get it out in the spring and start tuning for boost!
TD04H-13C water cooled turbo from a Volvo 930.
Homemade hot and cold sides.
2.5" exhaust
'94 Civic OBD1 240cc injectors
Kept both factory electric cooling fans and air conditioning.
Stock radiator, exhaust manifold.
Relocated battery to drivers side and downsized to a lawn mower sized battery.
40 mpg all around.
tiagolopes
Post by tiagolopes »
Mazda 323f BG 1994 full engine swap 1.8 dohc turbo BP26 JDM
FMIC and FM oil coller.
Exhaust 65mm
ZT-2 wideband egt and IAT.
walbro 255l
sytec fuel pressure regulator @ 3bar.
and now the MS2-extra
Vanhoe
Post by Vanhoe »
Reynard formula 3 903 from 1990 converted to F2 regulations for hillclimbs with OPEL/Vauxhall 20XE high compression ratio engine 230 BHP
Opel kadett limo 1978 with opel 20xe engine 196 Bhp
