How many engines running on MS2/Extra
Does you engine run?
I have an engine running on MS2/Extra
662
100%
Total votes : 662
Re: How many engines running on MS2/Extra
Postby PunkboySL2 » Fri Jun 03, 2011 11:50 am
94' Saturn Coupe, t3/t4, stock motor, 720ccs, Running 2.1.0p, had it running pretty good for about 2 months and made 202whp on only 7psi. Upgraded firmware and now I'm trying to get it running again since it doesn't want to start.
1994 Saturn SC2 Turbo, MS2v3.57 - under construction
1994 Saturn SW2 T3 7psi, daily driven, MS2v3.57
PunkboySL2
Postby deraffe » Sun Jun 12, 2011 1:01 pm
1991 325i
2.7i stroker motor with super ETA pistons, Dbilas ITB's, 292* dbilas cam, cone filter with custom airbox, ebay headers, no cat, magnaflo muuffler for resonator, B&B cat back.
no dyno results as yet.
running MS2 extra 3.1.1. with wasted spark, launch control, batch fire injection, on a modified stock wiring harness.
deraffe
Postby CODE4 » Tue Jun 21, 2011 6:17 pm
Just made the jump from MS1 to MSII.
Rewired the whole engine bay and power distribution. 1999 Mitsubishi Eclipse, 2.4 swap, Garrett GT3076R, Crower Stg 3 Cams, RC 750s.
MSII v3.0, sequential injection, 4 bar w/baro, p&h board, full standalone on 3.0.3y.
D. Tsang
SGT/USMC
1999 Eclipse - 2.4EDZ Squirtin & Boostin
MSII 3.0, 4 bar, seq, p&h. 406 whp/393wtq
CODE4
Postby TricK » Fri Jul 15, 2011 11:01 am
Mine is running also:
1973er Beetle 1303 with MS2extra V3.11
here are some pictures and a movie
Beetle 1303 1973/1970, 2,4l Typ 4 Remmele Engine, MS2extra V3.10, 48mm VGS Throttle Bodies,
CarPC with 7" Touchscreen for Tunerstudio and Multimedia, EDIS4 Ignition
Pictures
Movie
TricK
Postby mariob » Sat Jul 16, 2011 2:04 pm
this one has a 12-1 Hall-Trigger and a MS-controlled spark now:
It is based on a Simson/Awo 425S and modified for classic races:
- around 100kg when ready for takeoff
- 247cm³, bore/stroke 68/68, hemispheric combustion chamber, compression ratio ~10,5
- very lightweight ohv valvetrain with aluminium push rods and hair-pin springs
- around ~22-24hp@~8500rpms
- at the moment one 30mm carb
If i find a solution for enough electrical power (the space where the alternator was sitting was cut away to save some weight) the next step will be to remove the carb and fit a 35mm throttle-body and an injector. :)
Best Regards, Mario
Peugeot 106 Sergio_Tacchini, 1124cm³, MS2/Extra pre3.3alpah15, E85
Citroen AX, 954cm³, MS2/Extra pre3.3alpha15, E85
Peugeot 106 Rallye, 1298cm³ ... waiting for ITBs and full sequential injection
mariob
Postby R100RT » Sun Jul 17, 2011 9:20 pm
Recently joined the ranks of Extra code, on 3.1
My project is listed over on the success stories, but it changed physically so drastically this winter, that by rights it is like a different machine, and project really.
Details:
-1983 BMW R100RT MotorBike (988cc air cooled, opposed cylinder boxer engine, Nakasil liners, dual plug heads, etc.)
-Delphi injectors, sensors, MS ecu's, LCI wide band, etc. & much advice from helpful guys @ DIYA
-Some donor parts from Honda CTX650 "turbo" donor bikes (exhaust "Y" collector castings, and dual throat throttle plate plenum chamber assembly)
-Mitsubishi #TD025M-08T-3.3 Turbo, with aftercooler fabrication from 1/2 core from Sabb 900
-Exhaust manifold pipes and outlets from 321 SS mandrel bends (to avoid the ever hazardous "intergranular corrosion" that results from high turbo manifold temperatures)
-Water injection with miniature Peerless 12vdc diaphram pump that develops 80psi @ 120ml/min through ultra fine SS fogging nozzles from MacMaster Carr stock. 4L reservoir is hidden within rear upright seat.
-Tested to 23psi boost levels which correlate to uppermost rpm zone of turbo map, but presently tuned to 7psi.
-Stock bikes with Bing Carbs require highest octane gas to avoid "pinking", however I'm able to now use lowest octane without issue (and at substantial savings)
Other photos or details available
Almost forgot, underachieving stock Bosch crankshaft mounted alternator (280W on a windy day) upgraded prior to MS project, with a 900W compact Mitsubishi Alternator (by upgraded I refer to serious fabrication and machine work to shift to a frontal belt drive system - however was ideal lead in to a project that tends to request more electrical power every time you add something. :lol: :lol:
Lorne :D
1983 BMW R100RT Bike
Turbocharged - Water Injection
Sequential Ignition is great
"Perky Sleeper"
New toy - 1995 BMW K75 is on "The Mod Table", another V2 vintage Microsquirt kit'n caboodle ready to add, turbocharger in process, all the "usual suspects"
R100RT
Postby alan1977 » Thu Aug 11, 2011 6:48 am
BMW M50tu (Vanos)
running entirely on stock sensors and loom
19lb ford motorsport injectors
ms2e 3.1, batch fire,wasted spark COP fired of oem drivers
currently running on another MS user's 2.8 map
starting refining tonight, car runs close to stock already very pleased.
alan1977
Postby bbracing1 » Sun Aug 14, 2011 8:51 pm
I run a MS2. It took some time but I built everything. Help is very hard to find when it comes to programming. Take a look at the finished product. I have a 15" flat screen to display everything. http://www.youtube.com/watch?v=gRm88aeayAA
bbracing1
Postby 550R » Sun Aug 21, 2011 10:19 pm
I have 3 engines running MSExtra.
Josh
HONDA 2005 TRX 550R GT22 Turbo MSExtra 2.89
HONDA 2007 TRX450ER GT15 Turbo MSExtra 3.1.1
KAWASAKI 2005 KFX 700 MSExtra 2.89
550R
Postby Nimdah » Fri Sep 16, 2011 12:17 pm
20v 4age sc14 supercharged running on MS2 extra. Using stock dizzy and the Zeal engineering daughterboard. Wicked cool.
Nimdah
Postby Nick Jones » Sun Sep 18, 2011 12:34 pm
Triumph 2.5 PI previously clockwork then MS II B&G 2.89. Runs ok though the firmware change has deranged the fuel map somehow - need to map it again.....
Nick
Nick Jones
Postby CODE4 » Sun Sep 25, 2011 7:28 am
CODE4 wrote:Just made the jump from MS1 to MSII.
http://zero-signal.org/MSII_bay.jpg
http://zero-signal.org/front.jpg
Thought I would update this post with a dyno sheet :) (Check link for full size image - forum cuts the thumbnail resolution in half)
http://zero-signal.org/2.4L/dyno_sheet.jpg
D. Tsang
SGT/USMC
CODE4
Postby Jonpro03 » Sun Sep 25, 2011 2:20 pm
Nice numbers!
Jonpro03
Postby carphappy » Mon Oct 24, 2011 12:26 pm
running ms2/extra in my jdm ej20g tdo4 powered porsche 914. 6/7 trigger. took a while but it runs great.
carphappy
Postby carphappy » Wed Oct 26, 2011 7:08 pm
1976 porsche 914, jdm ej20 subaru motor, tdo4 turbo. here is a list of most of what i have done to the car. new carpets, head liner and mats, new window cranks, rebuilt door handles, customized driver side door storage, rebuilt glove box, custom rear panel, custom air intake in front to radiator, extra hood release, pioneer deh-6300ub stereo and 4 speakers, custom center console with 4 gauges and 2 speakers (innovate air/fuel, oil pressure, water temp, boost), customized shifter with custom boot, refurbished visors, ate vw fox big brake upgrade in front, rebuilt rear calipers (green stuff pads), new hard and flexible brake lines, new 19mm master cylinder, replace proportion valve with “t” fitting, new clutch cable, customized rebuilt peddle assembly with brass bushings, custom shift linkage bar, jdm ej20 subaru motor, 250 hp stock (450 cc/min injectors, relocated tdo4 turbo, wrx intercooler, custom tubing), summit electric fuel pump, kennedy adapter and fly wheel, stage 2 clutch and pressure plate, custom 3” exhaust, stainless ansa muffler, cx racing 3 core aluminum radiator with 2 12” electric fans, custom radiator cowl, refurbished fuel tank, electric windshield washer pump, 140lb rear springs, ats 15”x7” classic wheels with bfg sport tires, battery relocated to trunk, megasquirt ecu (ms2/extra, tuner studio running modified sti ignition map, innovate wide band o2 sensor, electronic boost controller), custom heater core in modified stock heater box, custom rain collector in engine compartment, stock engine temp. gauge used as oil temp gauge, custom rear wheel fender liner, among other things. photos taken before springs were installed. looking to get on the dyno in the spring, aiming for 275-300. any questions just ask.
finally made a video, check it out at:https://www.youtube.com/watch?v=7QBvLg2ulqM
carphappy
Postby Fausto » Fri Oct 28, 2011 6:22 am
Citröen engine XU10J4RS (or RFS).
Original: 4 cylinder, 4 stroke, 2.0L, 16 valves, 167hp.
Before MS: 136whp, gasoline.
After MS: 189whp, ethanol.
Citröen ZX Dakar Xu10j4rs, MS2 v3, Extra 3.1.2b, JB's full sequencial, 28lbs inj, Wasted COP, Gasoline;
Fausto
Postby rx7locost » Tue Nov 01, 2011 6:08 am
My car is a 1960 Lotus Seven home-built replica (not a kit) running a ’91 Mazda RX-7 normally aspirated rotary engine. The engine is rebuilt as stock with a custom intake manifold and headers. Crank angle sensor has been modified with 2 missing teeth. Oil injector pump has been eliminated. I am running premix. I recently added Bluetooth communications for 14 bucks. I’ve been on the road since March and have had over 2,000 miles logged. I’m still doing some fine tuning when I get the chance.
My setup is MS2 on a V3.0 PWB running 3.1.0 firmware. The MS2 is controlling fuel and ignition, dual speed fuel pump, Aux ports, and cooling fan. MS is wired directly to the highly modified RX-7 wiring harness with no expansion board, just the main MS2 controller.
rx7locost
Postby les_garten » Wed Nov 02, 2011 10:20 pm
R100RT wrote:Recently joined the ranks of Extra code, on 3.1
Details:
Lorne :D
I have an R100RT I would like to EFI and would like to get in touch with you about some questions I have about your bike. Is there a PM function here?
<<Les Garten>>
1992 BMW R100 needs The Squirt!
les_garten
Postby R100RT » Thu Nov 03, 2011 5:14 pm
Sure "Les_Garten", I believe if you go to a person's post and click on their signature, that takes you to a page where you can email and such.
Lorne
"Perky Sleeper"
R100RT
Postby dhallilama » Fri Nov 11, 2011 4:07 pm
1972 Volvo 142e, B20. It was formerly injected via Bosch D-Jet.
B20 is a 2 liter pushrod 4 cylinder. predecessor to the B21/B23/B230 OHC motors.
Currently running MSII, extra 3.1.1.
1000cc Delphi injectors with resistors, GM 2 post coils in wasted spark driven by BIP373 coil drivers.
engine is 8.7:1, Holset HE251cw turbo, few other things going on.
cold start is perfect, still working on warm up drivability but it's not horrible.
once it's at operating temperature, drivability is better than it was at it's best with D-Jet.
cruise is good, WOT is an absolute blast. boost comes on like a freight train.
dhallilama
PreviousNext
