Under the Dwell Settings Needs Changing to % menu or Battery Voltage Compensation menu, What are the recomended voltages? Should voltage 1-6 be an offset of 12v (i.e. -.5v, -1v) or are they actual voltages (i.e. 11v, 11.5v)?
If this menu is left untouched, will this hinder the dwell or just get cancelled out?
Dwell Setting %ages
The defaults in there come from base MS2. The voltages are offsets +/- from 12v and the dwells +/- from the nominal dwell.
You could set everything to zero if you wanted no voltage dwell correction.
The alpha code uses a %age curve instead.
