USB-serial adapter compatability list
Re: USB-serial adapter compatability list
Postby Marek » Thu Sep 26, 2013 12:54 am
I have used one of these between MS3 and TS 2.2+ and Win7
No brand name
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 277wt_1128
kind regards
Marek
Marek
Postby Moving_Target » Thu Sep 26, 2013 11:35 pm
IOGear GUC232A connected to an ACER Aspire 5742-6858 laptop running Win7 is working fine for me here.
1993 BMW 318is with a 5.0 SBF TFS H/C/I engine and Tremec T5 transmission aka a BimmerStang
MS2 Extra running batch fire and TFI ignition
Currently solving teething issues and tuning
Moving_Target
Postby Streetking » Sat Jan 18, 2014 10:41 am
My experience - none is working while laptop inside car,as soon as I move laptop to car roof it's running no problems.. tried HP and brand new Sony Vaio laptops, it looks they are poorly shielded, I shielded the adapter in aluminum, makes no difference,once laptop inside TS goes offline. Bought old laptop which has serial port,problems gone ;)
Streetking
Postby crazy3rdgen » Fri Feb 14, 2014 10:41 pm
Anyone noticing their previous firmware with a serial USB converter that used to work great no longer working correctly with the latest firmware after updating? Having weird online/offline issues without the engine even running after upgrading from an old firmware. I have the 6' gigaware serial USB converter.
crazy3rdgen
Postby Per J » Sun Feb 23, 2014 11:20 am
Yes my Aten usb adapter is no longer working correctly.. Goes offline and online shortly after every 20 sec approx..
/per
Per J
Postby luckythirteen13 » Fri Mar 07, 2014 1:03 am
The one sold by diyautotune.com works perfect on my windows 8 computer. Took a whole 30 seconds to install the drivers
luckythirteen13
Postby travm » Sun Jun 01, 2014 8:47 am
Just built a ms2 and the Dev11814 from Sparkfun I had lying around works great.
https://www.sparkfun.com/products/11814
Trav
ms2extra, v3, Rover 4.6l
travm
Postby Yves » Wed Jun 18, 2014 2:37 pm
Someone here sells racepack usb/rs232 adapters. Are these any good ?
Yves
Postby kingcrunch » Mon Jun 30, 2014 1:09 pm
luckythirteen13 wrote:The one sold by diyautotune.com works perfect on my windows 8 computer. Took a whole 30 seconds to install the drivers
X2 on Win 7 64bit running on a HP Elitebook.
kingcrunch
Postby Juan_Pa » Fri Oct 03, 2014 11:55 am
nice thread... Im using a Steren Profilic 2303-HXA chip under windows 8, no problem..
Juan_Pa
Postby 1vayl0Pavl0v » Sun Feb 22, 2015 3:48 pm
Works perfect with MS2 => HAMA USB-RS232 53325
1vayl0Pavl0v
Postby Davie Sprocket » Sun Jul 05, 2015 2:59 pm
Just getting back in to building my efi setup for my camaro. Its been awhile since I connected to the ms2-v3.0 board, my usb to serial dongle didn't work. Thanks to other guys that have posted here and the how to for usb, I didn't want to cut the traces from the max232 chip, so I pulled the chip off the v3 board and wired a cheap pl2303 d-sun usb to ttl that I had lying around for arduino. Works great and its fast. If anyone is building a board don't install the max232 or what ever serial to ttl chip that comes with your kit. Install a usb to ttl convertor they are all over the arduino sites and can be had for 5 to 10 bucks.
71 Camaro SS clone, 406 SBC. Dart Iron Eagle Heads, Comp cams,TH400 Trans, Diyautotune 36-1 wheel and pickup,TTR Ign Sys MS2-MS3expansion Board.
Davie Sprocket
Postby jrods2 » Mon Jul 20, 2015 4:42 pm
I've got the DIY usb 2920 adapter. I've been working with it steady for about 2 weeks and it's hit or miss. Usually start computer with it plugged in and then pull up TS and maybe it'll connect maybe not. All I know is it is not dependable enough to use for going for a ride to tune. If everybody will post an opinion for what they think is the best I will decipher the data and purchase that adapter. Thanx USE THE QUOTE FEATURE TO RESPOND
jrods2
Postby piledriver » Mon Jul 20, 2015 7:00 pm
Quick note on the MicroConnectors dual USB adapter, killed two, doesn't seem to like 5V on pin 9 of the serial connector
(to provide power for BT)
Installed a connector saver and broke off pin 9, no issues with the latest one. (need to remove the 5v jumper, will eventually)
Works on Win 98r2>Win10 and all Linux since kernel 2.4.0, MS1/2/3.
piledriver
Postby piledriver » Mon Jul 20, 2015 7:02 pm
jrods2 wrote:I've got the DIY usb 2920 adapter. I've been working with it steady for about 2 weeks and it's hit or miss. Usually start computer with it plugged in and then pull up TS and maybe it'll connect maybe not. All I know is it is not dependable enough to use for going for a ride to tune. If everybody will post an opinion for what they think is the best I will decipher the data and purchase that adapter. Thanx USE THE QUOTE FEATURE TO RESPOND
Turn your update rate down. If higher than machine can handle, it will drop out and reconnect randomly.
piledriver
Postby Jazracing » Thu Jul 23, 2015 11:19 am
I have been using this:
http://www.amazon.com/gp/product/B006PI ... ge_o04_s00
It seems to connect to my Microsquirt just fine.
Jazracing
Postby jrods2 » Tue Aug 18, 2015 5:48 pm
jsmcortina wrote:Please post here results on USB-serial adapter.
Keep this topic "clean", any off-topic ramblings will be split or deleted. I'll aim to compile the reports into one sticky once data has been collected.
I'll start.
"Prolific 2303" seems to work fine @115200 with Windows and Linux.
FTDI232 based serial - works ok. Used by Spectre in the EMS-Pro unit. Positive feedback from 6040solder
Hey James, I'm having trouble connecting again. If I change the port number to a brand new number From 1 To 2 I can connect only once to that port(2). I've gone threw to port 13 and it's the same every time. new port connect only once to it. I'm thinking I got a bad computer. I've moved the cable a couple of times & got an instant disconnect but if left alone it will disconnect by itself. I changed to a friends computer and was able to connect for 6 hrs. Now I'm looking at buying a new computer but I found a refurbished Dell with a DB 9 connector windows 7 & upgradable to windows 10, it's only and hundred bucks but I'm thinking that I will load everything on to it then disconnect from the internet and dedicate it just for the mega squirt. it's a tower computer so I won't be able to do a drive & tune. Can you give me some advice on this topic?
jrods2
Postby piledriver » Wed Aug 19, 2015 12:29 am
In Windows, go into device manager, open the driver prefs, and set the com port number for the device.
It will stop moving, guaranteed.
I ran into something like this once under Linux, but it started working properly again almost as soon as I noticed, could have been a tuner studio or kernel update that fixed it.
Buy a used Thinkpad.
Real RS232 ports aren't all that, and have their own set of fun issues.
A decent real FTDI or Prolific (not a counterfeit, sadly common) USB adapter is a huge improvement as far as Megasquirt is concerned.
MS3 has the FTDI adapter built in.
piledriver
Postby damo99 » Thu Jan 21, 2016 6:22 pm
i run the prolific tech pl2303 on windows 10
it works great
welcome to the internet ,where men are men, women are men and little girls and boys are FBI agents
injected 5.7 mitubishi triton
61 kombi 2270 type 4 microsquirt
tf cortina 302 windsor
66 shovel nose corona 18rg twin cam
damo99
Postby cdesigns » Sat Jan 23, 2016 3:59 am
Radio Shack Gigaware USB to Serial (white cable with big square bump at the end) only works with Firmware 3.2.5 or below.
I tried all the firmwares and it will disconnect by itself if using firmwares higher than 3.2.5.
cdesigns
PreviousNext
