Low Z noise problems
SymTech Laboratories
Re: Low Z noise problems
Post by SymTech Laboratories »
Rikard wrote:The mod that Sprig is talking about, is that the same mod that is documented on page 29 in this document?
http://www.bgsoflex.com/megameet2008/me ... gnding.pdf
Or is this something else?
Yes, it sounds like he's talking about the same modification. You can also clip the center pins on Q9 and Q12, and connect them to the DB37 connector with a piece of wire for a similar effect.
SymTech Laboratories, LLC ----- MSQ File Repository: megasquirt.symtechlabs.com
Tippy
Post by Tippy »
I too have MS2 v3.57 running low-Z's (qty 6) and dealing with voltage spikes. Sometimes it hits 21 volts.
I've read this thread several times (and Megameet) and it seems there has been many, many solutions to this issue but it seems no two are alike from others who have posted.
Is there a solution that does not require hacking a trace that is 100% guaranteed to work? Or is it trial-and-error?
'87 Porsche 911 turbocharged (Borg Warner S366/1.4 bar) 3.4L w/MS2 v3.57 running Ford EDIS-6
Peter Florance
Post by Peter Florance »
Tippy wrote:I too have MS2 v3.57 running low-Z's (qty 6) and dealing with voltage spikes. Sometimes it hits 21 volts.
Page 18 of this thread; make sure your system passes the grounding test I suggest
http://www.msextra.com/forums/viewtopic ... &start=340
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Tippy
Post by Tippy »
Peter Florance wrote: Page 18 of this thread; make sure your system passes the grounding test I suggest
Peter, my grounding is exactly like the diagram you posted in that thread. All grounds from MS go to my intake (same ground lug Motronic uses) on one single lug. Is that the test?
Peter Florance
The test is, if you unplug MS box and measure resistance from any sensor's (MAT, CLT, TPS) ground to car/engine ground , you should not have continuity.
Peter Florance
PF Tuning
Peter Florance
I hope no one else cuts up their ms board before checking the sensor grounds.
Peter Florance
PF Tuning
psucrash
Post by psucrash »
I know that this is an old post but I wanted to add my thanks to you Mr. Florance!
I have been having battery voltage spike issues for a long time and tried all kinds of things to remedy the situation.
Found this post and placed a 47uF cap as you described. PROBLEM SOLVED!!
The battV actually looks more noisy now but that's because it's scaled from 12.5 to 14 volts now. It used to autoscale from 7 to 19 ...
The car would misfire hard when I had the spikes under boost. Now it's a clean pull straight through :yeah!:
'86 Mitsubishi Starion MS2extra v3.0 3.2.5. 363WHP/418TQ Built not bought
400WHP+ runs to come!
Peter Florance
Great; glad it helped.
Also check the grounding per my above test. The systems are amazingly quiet if they can pass the sensor ground test.
Peter Florance
PF Tuning
f3rdy
Post by f3rdy »
I'm a little bit stumbled. For wiring of most components, like PWM idle valve, relays etc a diode is suggested for protection the mosfets or transistors driving it. However when using mosfets or transistors that are avalanche protected these diode will be less necessary to protect the driver (e.g. irf 540N). But without diodes nasty voltage spike can occur. Why don’t we use diodes in the injector wiring harness? :RTFM:
Peter Florance
f3rdy wrote:I'm a little bit stumbled. For wiring of most components, like PWM idle valve, relays etc a diode is suggested for protection the mosfets or transistors driving it. However when using mosfets or transistors that are avalanche protected these diode will be less necessary to protect the driver (e.g. irf 540N). But without diodes nasty voltage spike can occur. Why don’t we use diodes in the injector wiring harness? :RTFM:
With injector drive, you need the clamped spike to close the injector quickly.
If you use a rectifier to recirculate the energy at turnoff, the closing time can increase more than 200%.
Peter Florance
PF Tuning
To add to what Peter said, the higher the voltage the back EMF is allowed to reach, the more quickly the injectors will close. The active flyback clamp circuit on the v3.0/v3.57 board clamps the voltage to 36V, whereas a 1N400x diode would clamp the voltage to ~14V.
JW3vze4RnR
Post by JW3vze4RnR »
i am also having this issue. before i opened up my ms again i wanted to be clear on what works and what is speculation..
before i even bother, i am running one 1.3 ohm injector in a tbi do i need to run it with pwm
i havent been but my ve table is kind of stretched out from 30 to 212
still not clear on were to attach the "closer to the db37" source for 12v.
is that the incoming 12v supply for ms or another line i need to run to a different pin on the db37
im not perfectly clear on the voltages on these capacitors or if it is matters whether its 35v or 50v
here is what i have come up with by reading this and various other threads,
i did not add cutting the trace or rewiring the transistor leads as i wasnt going to attempt this yet
photo was borrowed from a mustang forum
91 4runner 3vz-22r swap, gm 2.5 tbi, edis 4, ms2 3.0
Peter Florance
JW3vze4RnR wrote:i am also having this issue. before i opened up my ms again i wanted to be clear on what works and what is speculation..
Before I did any of that, I would verify that your harness meets the newest MSExtra grounding scheme. Your setup should pass this test:
If it does pass above, you may find you can run PWM without any other mods.
Peter Florance
PF Tuning
JW3vze4RnR
peter i have taken the sensor ground test and everything shows no continuity to ground when unplugged from ms..
furthermore i can run non pwm injection without noise or voltage spikes.
when switched to pwm injection using all the same hardware i get voltage spikes ranging from 9-17 volts causing my usb adapter and lc1 to shut down.
this is why i was looking to dampen the injection circuit and am looking for clarification that my above posted image is correct at least for the non invasive portions of pwm troubleshooting
Peter Florance
JW3vze4RnR wrote:peter i have taken the sensor ground test and everything shows no continuity to ground when unplugged from ms..
Good
you'll need fairly good sized wire for ground wires from MS to ground. I would use 6 ground wires minimum (most harnesses are coming with #20 gauge wire. I'll run all of them together and crimp them into one yellow ring terminal
For the capacitor, I normally will tack a 330uf 25 volt from collector of TIP125 (positive lead of capacitor) to collector of TIP42C. Then bend it towards heatsink and fasten down with hot glue. Should take care of your problem.
I run 6 low z injectors. I do have the capacitor added but nothing else.
One other thought; if your PWM is not working correctly (not recirculating current during the PWM time) you can generate a huge amount of noise.
Peter Florance
PF Tuning
moparmaniac
Post by moparmaniac »
Peter Florance wrote:I've been dyno tuning a TR8 this week (8 low z injectors)
The injector noise has been very low.
47uf 50v cap from center leg of TIP42C to TIP125
That's all I ever do for low Z injectors. I do a lot of jobs with 6 injectors. First V8.
I do above and provide plenty of ground wires.
Recently been having a noise issue so bumping this back up.
Do you not also run the same .47uF 50V capacitor from Q11 to Q12 (center leg to center leg) or is just one bank enough to cover the noise...?
Thanks,
-Colin
Peter Florance
Thanks,
-Colin
Just one bank is enough.
Peter Florance
PF Tuning
moparmaniac
So I've added a non-polarized .47uF 50V capacitor as you described and am still seeing noise on my tachometer when testing the injector outputs.
I guess I could try a larger capacitor...? Or does the capacitor need to be polarized?
moparmaniac
moparmaniac wrote:So I've added a non-polarized .47uF 50V capacitor as you described and am still seeing noise on my tachometer when testing the injector outputs.
I bought a 47uF (not .47uF) 50V capacitor (polarized this time) and soldered that in as described by Peter.
WORKS AWESOME! That was literally all I did. No lifting traces or anything.
I have absolutely NO noise. My LC-1 is happy (AFR rock solid), all sensor inputs are happy (much more crisp IAT/TPS/etc.), and no more battery voltage sags/spikes. For reference I'm powering 6 low-z injectors on a Mopar 440 v8.
THANK YOU PETER!!!
neverlift19
Post by neverlift19 »
v3.57 board
"47uf 50v cap from center leg of TIP42C to TIP125"
on my board I have tip126 and a quick google search shows them to be in the same family, just slightly different ratings. Am I justified to say its safe to do the modification?
ka24de-t 12-1 diy trigger wheel
880cc
t3/t04e 57 trim 11psi
blaster coil
ms2 v3.57 on 3.3.1
