Low Z noise problems
Re: Low Z noise problems
Postby SymTech Laboratories » Fri Apr 12, 2013 9:10 am
neverlift19 wrote:on my board I have tip126 and a quick google search shows them to be in the same family, just slightly different ratings. Am I justified to say its safe to do the modification?
Yes, it's safe to do this modification.
SymTech Laboratories, LLC ----- MSQ File Repository: megasquirt.symtechlabs.com
Postby neverlift19 » Fri Apr 12, 2013 3:59 pm
thanks I will report back later!
ka24de-t 12-1 diy trigger wheel
880cc
t3/t04e 57 trim 11psi
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby neverlift19 » Sun Apr 14, 2013 12:49 pm
Couldn't find a 50v 470uf cap but I did dig a 25volt off an old brushless speed controller, curious if the voltage is really important?
Joshua
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby dontz125 » Sun Apr 14, 2013 2:07 pm
You're trying to control flyback voltage, which will be significantly higher than 25v. Are you sure you want a 470uF? The others have been talking about 47, or 0.47 ...
dontz125
Postby neverlift19 » Sun Apr 14, 2013 2:54 pm
Honestly I dont know, I see some using 47uf some using 330uf .47uf I am honestly not sure and some of the links are dead :x I didnt get to go far on my test run... no log..
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby SymTech Laboratories » Sun Apr 14, 2013 6:05 pm
neverlift19 wrote:Couldn't find a 50v 470uf cap but I did dig a 25volt off an old brushless speed controller, curious if the voltage is really important?
The flyback voltage is clamped to 36V, so you really need a 50V+ rated capacitor.
Postby neverlift19 » Sun Apr 14, 2013 7:57 pm
ok will get on that tomorrow. So whats the uf rating I 'should' be getting or is that a test and tune type of thing?
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby kjones6039 » Sun Apr 14, 2013 8:01 pm
FWIW.......
I have been using a 47uF/63v without issue......
MS2 v3 w/extra 3.4.2 Release
kjones6039
Postby moparmaniac » Mon Apr 15, 2013 6:01 am
Again, I'm using a 47uF 50V polarized (NOT bipolar) capacitor. Solved all of my noise issues.
moparmaniac
Postby neverlift19 » Wed Apr 17, 2013 12:55 pm
grr my radioshack is weak, a bunch of non helpful people work there. Almost blank faced when I asked about a polarized 50v 47uf cap... highest they had in stock was 35v so I guess I need to order online or see if anyone has one laying around, still getting voltage spike and sag however its a lot lower! msq below.
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby SymTech Laboratories » Wed Apr 17, 2013 1:16 pm
RadioShack carries a 100uF/50V capacitor (P/N 272-1044) that should work fine.
Postby neverlift19 » Wed Apr 17, 2013 3:07 pm
I'll try that out next! The 47uf smoothed out the intensity a LOT down to within a 2 volts of swing vs 11 volt swings :yeah!:
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby neverlift19 » Thu Apr 18, 2013 12:32 pm
,6 volt swing I can completely live with THANKS YOU GUYS :yeah!:
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby SymTech Laboratories » Thu Apr 18, 2013 12:33 pm
Great! Thanks for reporting back!
Postby neverlift19 » Sat May 18, 2013 9:30 am
after more logs the 100uf has much larger swing than I originally saw, it is closer to a 3 volt swing, found a 47uf 50volt cap I am going to try out today. Update later.
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby Peter Florance » Sat May 18, 2013 9:41 am
neverlift19 wrote:after more logs the 100uf has much larger swing than I originally saw, it is closer to a 3 volt swing, found a 47uf 50volt cap I am going to try out today. Update later.
Did you ever perform the sensor ground test?
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Peter Florance
Postby neverlift19 » Sat May 18, 2013 1:28 pm
yes passed that, as soon as I read that I went and checked took 30 seconds :D
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby neverlift19 » Mon May 20, 2013 8:03 pm
have not logged to see if its smoother yet, been doing wiring and adding stuff :D
should I add this mod to the idle pwm too? have yet to set pwm for idle but its on the list for tomorrow morning.
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby neverlift19 » Thu May 30, 2013 5:36 am
ok after a few logs this is way worse. Its a very shaky swing of over 4 volts now. Undrivable at night with any electrical load :(
880cc
blaster coil
ms2 v3.57 on 3.3.1
neverlift19
Postby yellowlt1ta » Fri May 31, 2013 1:27 pm
I added a 47uf 35v polazided on the center legs of Q3 to Q9 with the negative side on Q3. none of the legs where lifted. is this right? this is on a v3.57
I have been using it like this and still get noise. I have my grounds done the correct way too.
'93 Trans Am LT1 80mm turbo
yellowlt1ta
PreviousNext
Users browsing this forum: Bing [Bot] and 4 guests
