Low Z noise problems
Re: Low Z noise problems
from what I was told on the last page no a 35volt cap will not work as the circuit is clamped to 36 volts. Although I got better reading with the 35 over the currently installed 50volt .. Personally going back to the 100uf
ka24de-t 12-1 diy trigger wheel
880cc
t3/t04e 57 trim 11psi
blaster coil
ms2 v3.57 on 3.3.1
880cc
blaster coil
ms2 v3.57 on 3.3.1
It should ok. It would not work in the injector output, but you are installing on 12v rail. Which only has a few volts of noise on it.neverlift19 wrote:from what I was told on the last page no a 35volt cap will not work as the circuit is clamped to 36 volts. Although I got better reading with the 35 over the currently installed 50volt .. Personally going back to the 100uf
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Also make sure you have enough ground wires from MegaSquirt to ground. In your setup, I'd run eight 20ga minimum.
Peter Florance
PF Tuning
PF Tuning
peter can I put 8 wires on a single pin off the DB37 for ground?Peter Florance wrote:Also make sure you have enough ground wires from MegaSquirt to ground. In your setup, I'd run eight 20ga minimum.
also can you tell me if I did this modification correctly.
'93 Trans Am LT1 80mm turbo
Eight ground wires means use eight pins. One wire per pin.
ok, can I use one of the pins for multiple sensor grounds?jsmcortina wrote:Eight ground wires means use eight pins. One wire per pin.
and is the picture correct?
There are 15 ground pins on the DB37 - #1-2, then 7-19. Pick any 8 from 7-19 for your system grounds, use #1 and/or 2 for your sensor return(s).
Yes, one wire for all sensor grounds is good.yellowlt1ta wrote:ok, can I use one of the pins for multiple sensor grounds?jsmcortina wrote:Eight ground wires means use eight pins. One wire per pin.
Capacitor photo looks fine.
Peter Florance
PF Tuning
PF Tuning
so on the stim the logs look good but when I add one injector it still gets lots of noise.
check it out.
check it out.
any ideas? Iv been thinking that I should some how take out the injector ground from the megasquirt.
usually the stim is a little noisier than the car, for me anywayyellowlt1ta wrote:any ideas? Iv been thinking that I should some how take out the injector ground from the megasquirt.
Peter Florance
PF Tuning
PF Tuning
well I have put a ms2 v3.57 on a turbo mustang and have tryed everything to clean all the noise up. and this is as close as I have gotten
Thing is that I try to clear the noise on my car but nothing works. everything is the same, except that I use low-z injectors.'93 Trans Am LT1 80mm turbo
Just need some clarification,am I putting a 47uf 50v capacitor from the center leg of Q3 to the center leg of Q9 and are any of the two legs lifted off the board?
Don't lift. More important to get sensor ground to standards.
Peter Florance
PF Tuning
PF Tuning
