Peter Florance wrote:...
On V3 boards, it absolutely works. I don't understand why all the hacked up boards, lifted and separated 12v lines etc.
It is interesting to me that STILL, to this DAY, there are flyback issues.
HACK the board, that is the ONLY way to keep the negative flyback from hitting the processor.
IF ANYONE HERE KNOWS ANYTHING ABOUT ELECTRONICS ...
The board design was the most effective way to make common connection points shown on the paper schematic.
In REAL LIFE, form factor matters. The physical PLACEMENT of stuff does REALLY matter!
After all this time, I can not believe this has not yet been put to rest with "the fix" that "I" developed as a standard solution.
Cut the trace on the board, add the filter cap, and ADD the flyback wire back to the SAME source connection point of the injector.
This is not worth three years of bickering over.
If you don't believe me ... you might want to had better duck ... the other mistake I made might be flying over your head...
