jsmcortina wrote:What input circuit are you using between the Flex Fuel sensor and the CPU pin itself?
S.Bretz wrote:jsmcortina wrote:What input circuit are you using between the Flex Fuel sensor and the CPU pin itself?
I had it jumper onto JP4 (not going throught the CPU pin) and it was doing the same thing
S.Bretz wrote:Karlo, do you at all remember what you changed/added to help with noise?
karlo wrote:I implemented a lag filter or sorts, restricting it to change only 1% on every sample. This fixed all my noise issues, and would still go from min to max fuel correction in around a second, which as you point out, is quite sufficient.
- Karl
jsmcortina wrote:S.Bretz wrote:jsmcortina wrote:What input circuit are you using between the Flex Fuel sensor and the CPU pin itself?
How does it connect from there to your FF sensor though?
S.Bretz wrote:IDK if you didn;t read my post or not...or are asking these guys.
...but as I stated. Its coming in on the JP4 and I have TS set to PEO.
If you are asking how its' built...the circuit is build like it states in the manual; to use a pull up resistor off the 5v on the proto board and hook up to JP4 on the MS2 card.
like this:
http://www.megamanual.com/ff_wiring.gif
Users browsing this forum: glowryder, Google [Bot] and 2 guests
