Pic of proposed Wiring
noticed it cuts off the right side so here is link http://upload.3sgtemr2.com/files/1/MS%20Wiring.jpg
and a description of how I "think" everything should be done, with a lot of help from russ at DIYautotune(THANKS!) kit will be arriving any day and wiring commencing next week.
-G- to pin 17
-NE- to pin18
-NE+ will go to pin24 (first ignition input)
-G2 will go back to pin3 which would in turn wire to the lm1815 daughter card?
-IGT1 would go to pin36 via d14 as ignition output1 (R26 top edge)
-IGT2 I would run to pin4 via D16 as ignition output2 (R29 top edge)
Ok, So thats pretty straight forward, Now for the megasquirt mods:
Megasquirt Mods
-VRout to Tsel
-Tachselect to VRIN
Zeal Daughtercard mods (2nd ignition INPUT)
-+12v to S12
-+5v to S5
-GND to SG and ProtoGND
-the lower VR2 hole to pin3,
-The upper vr2 hole to the sensor ground pin17
-Take the vr2out on zeal board and connect it to js10 on the mainboard.
Now for the Tuner Studio settings
-Tach Input/Ignition settings:
Spark mode:Toothed Wheel
Skip Pulses:3
Ignition output capture:Rising Edge
Spark output:Going low
number of Coils:Dual Dizzy
Spark A output pin: D14
Trigger Wheel Settings
Trigger Wheel arrangement:Dual Wheel
Trigger Wheel Teeth:12
Missing teeth:Greyed out
Tooth #1 Angle (deg BTDC):5
Wheel Speed:Crank Wheel
Second Trigger active on:Rising Edge
and every rotation of....:Cam
