R33 for V3.0 board MS2
Postby efims » Thu Jun 14, 2012 5:52 am
From the assembly manual
"Even if you have installed the PWM flyback damping circuit, you should install the standard flyback circuit as well (step #70).
70. To install the standard flyback circuit:
Install R18 and R33 {270QBK-ND, red-violet-brown}. These are located below R38 and Q1 on the heat sink."
I ran out of 270 Ohm...but I have a few 330 Ohm....can I use 330 Ohm for R33?
Thanks in advance
efims
Re: R33 for V3.0 board MS2
Postby damon308 » Fri Jun 15, 2012 4:04 am
Hi, Yes that should be fine, Regards DM
damon308
Users browsing this forum: Baidu [Spider] and 4 guests
