MS2/Extra 3.2.4 beta released
Post by jsmcortina »
3.2.4 is released with some bugfixes over 3.2.3
As per 3.2.3, TunerStudio > 1.51 is REQUIRED. Versions 1.00x will not work. Auto-update should handle this for you or go to http://www.efianalytics.com/TunerStudio/
Changes since 3.2.3
When mis-syncing at low rpms, dwell could be miscalculated causing spark hang-on.
Clear MAP sample error every 1 second
Dwell/discharge balancing
Rationalise adv_offset(triggerOffset) greying and usage and make it work like MS3.
All users of 3.2.x are encouraged to upgrade. Pending feedback, this release should be promoted to "release" soon.
Download the zip from: http://www.msextra.com/doc/ms2extra/fil ... 4_beta.zip
Peras
Re: MS2/Extra 3.2.4 beta released
Post by Peras »
Gave it a shot last night, drove around 50km, works well
When in doubt, flat out...
gslender
Post by gslender »
Hi James,
Where does this release sit compared to the Alpha 4 and upcoming Alpha 5 ?
G
Mazda MX5 + MS3 Pro
pmbrunelle
Post by pmbrunelle »
Is this in reference to the issue mentioned here:
http://www.msextra.com/forums/viewtopic ... 91&t=45125
Gokart
Post by Gokart »
gslender wrote:Hi James,
G
Now I get confused with several updated firmwares.
Alpha series have more features and I consider 3.2.x to be outdated but
3.2.x are updated and the alpha are just left behind.
(4G63T - MSIIextra) (4G13 - MS3-beta testing)
87quest-TSI
Post by 87quest-TSI »
G
This may help you.
http://www.msextra.com/doc/ms2extra/upg ... #codephase
89,88,87 Conquest TSI
1971 Jeep CJ5
MS2-V3.57 with map daddy, software 3.4.2 with EDIS on a Mitsubishi 2.6l turbo.
using Tuner Studio V3.0.28 / megalog viewer V4.1.17 and Shadow Dash V1.5.02
chacaman
Post by chacaman »
Upgrade from 3.2.1 to 3.2.4 FeedBack
Upgrade process:
Power on MS-II(EMS) using JimStim
export VE/Spark Table
Upgrade Firmware
Import VE/Spark Table
setup all from 0
Engine Workg Great, Sweet and Smooth
Only one Issue in my case:
i am using fan output the fan always stay ON
i made the next test:
1 - test
Engine Temp = 86C in the test moment
Enale = YES
Port = PT6 IAC1
Power On Value = 0
Tirgger Value = 1
Coolant = > 87.00
Hystrisys = 4.0
Result: Fan Always on
2 - test
Engine Temp = 82C in the test moment
Enable = NO
Port = PT6 IAC1
Power On Value = 0
Tirgger Value = 1
Coolant = > 87.00
Hystrisys = 4.0
3 - test
Engine Temp = 78C in the test moment
Enable = no
Port = PT6 IAC1
Power On Value = 0
Tirgger Value = 0
Coolant = > 0.0
Hystrisys = 0.0
Just load your existing MSQ into the new firmware, all the settings should come across ok.
chacaman
Post by chacaman »
all ready load and the same issue the fan stay on all time
Swap back to the previous firmware and see if the issue persists.
chacaman
Post by chacaman »
i have the same issue :x
but now turn off and turn on
what i have to check ? mmmm the 2N2222A is bad ?
aaronc7
Post by aaronc7 »
This one still looking to be the next "release" version?
aaronc7 wrote:This one still looking to be the next "release" version?
That's the plan, I've been busy on other things and haven't "pushed the button".
