question about cam sensor input on LS1
Car runs fine with crank only but does take a fairly long time to sync on startup . Will using the cam sensor input if available have any affect on this or anything else . Only reason I ask is there is a box that says "use cam if available " in LS1 decoder settings in tuner studio.
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: question about cam sensor input on LS1
The MS2/Extra LS1 mode does not use the cam sensor under any circumstances.
Copy that and I understand since you are the author but curiosity got the best of me and I wanted to ask why there is that setting on the ignition settings page says use cam if available yes or no . Thats all that got me to wondering
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
It says "if available" but it isn't available for LS1 so the setting does nothing.nismoautoxr wrote:Copy that and I understand since you are the author but curiosity got the best of me and I wanted to ask why there is that setting on the ignition settings page says use cam if available yes or no . Thats all that got me to wondering
I've removed that setting in MS3 already and will likely do the same in MS2 if I get time.
gotcha thanks James . I appreciate you clearing that up.Would that explain why I cant get the cam sensor to show up on the tooth logger? I initially wired a cam sensor and ran it to VR2 on my diypnp whether i needed it or not but couldnt see it in diagnostics.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
LS1 mode on MS2/Extra does not enable the cam input.
If you want to take a log of the crank and cam, switch to "log crank and cam" mode.
never seen that in my poking around. What tap is that found under?
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
