Lambda ?
Lambda ?
Postby bluebob » Tue Jun 11, 2013 11:01 am
I have one of these lambdas fitted to my car, question is which lambda do i choose in the drop down list?
1974 Range Rover Classic powered by a ls1 gen 3 5.7ltr coupled to a 4l80e ran with a compushift.
LS1 is ran using ms 2 extra
Newbie but learning all the time
bluebob
Re: Lambda ?
Postby myk777 » Tue Jun 11, 2013 12:13 pm
Most likely the one that matches the brand and model that you have.
Mike
myk777
Re: Lambda ?
Postby bluebob » Tue Jun 11, 2013 12:34 pm
http://www.ecolambda.co.uk/main/ecosale ... =250-24200
Its one of them above.
A walker wideband?
bluebob
Re: Lambda ?
Postby walterclark1 » Tue Jun 11, 2013 2:15 pm
That is a narrow band sensor. If you want wideband you need both a correct sensor type and a suitable controller.
A2 VW GTI 9A - MS3/3X
walterclark1
Re: Lambda ?
Postby bluebob » Tue Jun 11, 2013 3:07 pm
Ok, I was advised to get that one. Am new to all this, what difference does that make. Is a wideband better?
It for a ls1 corvette engine?
bluebob
Re: Lambda ?
Postby kjones6039 » Tue Jun 11, 2013 10:12 pm
bluebob wrote:Ok, I was advised to get that one. Am new to all this, what difference does that make. Is a wideband better?
Nonetheless, it is still a narrow band sensor. It is difficult to do any meaningful tuning without a wideband (IMO of course)!
MS2 v3 w/extra 3.4.2 Release
kjones6039
Re: Lambda ?
Postby bluebob » Wed Jun 12, 2013 2:47 am
Hi, which sensor would be best for a ms2 extra?
May aswell get the right one, or one that somone else has used.
bluebob
Re: Lambda ?
Postby DaveEFI » Wed Jun 12, 2013 5:01 am
bluebob wrote:Hi, which sensor would be best for a ms2 extra?
A narrow band sensor connects directly to MS, but only tells it if richer or weaker than stoich. A wideband sensor needs its own ECU which then connects to MS and gives the actual air/fuel ratio. Which means you can tune to the AF ratio you want at any point on the map.
There are several different makes on the market. I've got a Tech Edge, and my version was a DIY kit, same idea as MS, if you like building things.
DaveEFI
Re: Lambda ?
Postby aut0m4tic1 » Wed Jun 12, 2013 9:12 am
I use an Innovate LC-1 Tuner Studio has a default setting for it. It has 2 programmable outputs so it can feed the ms2, and also run a gauge or feed a stock ecu if you are running a parallel installation.
A narrowband can be usefull after your tuned, but not somuch with boost and your richer mixtures.
Cory
aut0m4tic1
Re: Lambda ?
Postby bluebob » Wed Jun 12, 2013 10:08 am
Thanks, The MS is a stand alone unit.
I dont mind building things, it helps you understand how some things work.
Where can i pick one up from then?
bluebob
Re: Lambda ?
Postby bluebob » Thu Jun 13, 2013 11:11 am
Hi, ok so i've located a supplier in the uk for the lc1, has anyone used one of these the MTX-L gauge kit?
Do they work with the megasquirt the same?
bluebob
Re: Lambda ?
Postby aut0m4tic1 » Thu Jun 13, 2013 11:47 am
I bought mine from a friend, but google it and you will find hundreds of places selling them.
Since your new to tuning, I would read through all the documentation for whatever MS your using, then go through all the posts in the tuning section, and you'll have a better idea about how things work.
Taking a few hours to read these two will save several times as many hours fumbling through tuning blindly.
You will find that there is a method to tuning every parameter, and its all in the documentation. Some of the docs need updating, so if the info isnt clear double check with ms2 and ms3 docs and it will probably be more obvious where to go.
Also, don't be shy to post if you cant find an answer, the MS community is great for learning and sharing info.
Cory
aut0m4tic1
Re: Lambda ?
Postby R100RT » Thu Jun 13, 2013 12:36 pm
Yes, I have an MTX-L operating I believe more stable than the LC-1 which I started with, and I would use it again.
I also have a gage from 14.7 which is much more compact, robust, and $$ effective.
I say that by reason of the fact that my LC-1 indicated the Bosch sensor was failed through flashing led code(s) and wouldn't work despite all manner firmware rework, but that same sensor worked trouble free with the 14.7 kit.
Lorne
1983 BMW R100RT Bike
Turbocharged - Water Injection
Sequential Ignition is great
"Perky Sleeper"
New toy - 1995 BMW K75 is on "The Mod Table", another V2 vintage Microsquirt kit'n caboodle ready to add, turbocharger in process, all the "usual suspects"
R100RT
Re: Lambda ?
Postby bluebob » Thu Jun 13, 2013 1:36 pm
Thanks for the advice.
I think ill try the MTX l gauge kit then.
Its meant t be easier to install also.
I'll let you know how i get on.
I'll read up a little more on tuning to.
Is there any videos on the website for intro into tuning?
Ian
bluebob
Re: Lambda ?
Postby bluebob » Sat Jun 22, 2013 12:24 pm
I got my MTX-L installed today, havne't run the car yet.
In te paper work i have 0v = 7.35 afr and 5v = 22.39 afr.
Which option do i choose in tuner studio?
bluebob
Re: Lambda ?
Postby kjones6039 » Sat Jun 22, 2013 8:02 pm
I believe that is LC-1 default.............
kjones6039
Re: Lambda ?
Postby bluebob » Sun Jun 23, 2013 12:57 am
Ian
bluebob
Users browsing this forum: derbybrit1 and 4 guests
