No power/bogging down under load
A112H
Post by A112H »
Hi all,
So after weeks of reading, messing, playing and altering settings I have a good idle and strong revs from 2500rpm to 6500rpm at full throttle.
Problem is when I stomp on it from idle it will crack, bang, fart and die. If I ease the throttle, about 40%, until revs reach 2500-3000rpm and then go 100% it is fine.
This is all in nutral in the shed, driving is another issue.
When driving, anything over 25% throttle and it bogs down like out of fuel feeling. Back the throttle off and all is well.
I am using a MSII V3.57. Engine is a Mitsubishi Astron 4G54 2600cc, fitted with ITBs. Fuel system is Bosch 775 221cc injectors fed by a Bosch 044 pump from a surge tank that is fed by a high volume lift pump. Sensor are narrow band o2, water temp, MAP sensor, TPS.
Not sure what other info may be helpful but I do notice the TPS accel enrich is flashing on a lot, could it be flooding the engine?
How to I adjust this setting?
These are my maps, any help would be greatly appreciated. TIA
grom_e30
Re: No power/bogging down under load
Post by grom_e30 »
can you post a log of the issue, how does it rev if you ease the throttle on?? if its better and revs fine than its more than likely an accel enrichment based problem, either to much or to little extra fuel for ae.
slow_hemi6
Post by slow_hemi6 »
One of the hardest things to get right with ITB's is the AE. Without a wideband to give you AFR feedback you are just taking stabs in the dark I'm afraid.
Cheers Luke
A112H
Post by A112H »
grom_e30 wrote:can you post a log of the issue, how does it rev if you ease the throttle on?? if its better and revs fine than its more than likely an accel enrichment based problem, either to much or to little extra fuel for ae.
Yep, easing the throttle on is okay. I think it is the accel enrich but don't know how to alter it.
This was the first decent setting.
https://www.youtube.com/watch?v=8g29RDuTswU
Then I got to this
https://www.youtube.com/watch?v=qtLQcB5xp4Q
But that is all free revving, it just dies on the road :(
Not sure how to log stuff or which log you would want, to be honest
A112H
Post by A112H »
slow_hemi6 wrote:One of the hardest things to get right with ITB's is the AE. Without a wideband to give you AFR feedback you are just taking stabs in the dark I'm afraid.
I feared this would be the answer Luke. So if I buy a wide band sensor what else do I need to make it work with the ecu?
On a different note, is there a way I can make the MS2 turn the thermo fan on and off?
A112H
Post by A112H »
#Firmware: MS2/Extra release 3.3.2 20140529 14:06GMT(c)KC/JSM/JB MS2
ToothTime Time
ms ms
37.73814 11562.75
37.15998 11599.91
36.71514 11636.625
36.98046 11673.605
36.67818 11710.283
36.48744 11746.7705
36.29934 11783.07
37.16658 11820.237
38.14008 11858.377
37.76784 11896.145
37.59756 11933.742
0 11933.742
0 11933.742
And
TriggerTime Time
ms ms
39.8475 4101.759
40.31874 4142.0776
40.00458 4182.082
38.8014 4220.8833
39.54654 4260.4297
40.07256 4300.5024
39.3855 4339.888
38.973 4378.8613
0 4378.8613
0 4378.8613
0 4378.8613
0 4378.8613
0 4378.8613
grom_e30
Post by grom_e30 »
http://www.msextra.com/doc/pdf/Megasqui ... ce-3.3.pdf have a read through section 4 about datalogging
slow_hemi6
grom_e30 wrote:http://www.msextra.com/doc/pdf/Megasqui ... ce-3.3.pdf have a read through section 4 about datalogging
or the condensed version is the forum help page. http://www.msextra.com/doc/general/forum_posting.html
Cheers Luke
rickb794
Post by rickb794 »
Yes, There are multiple outputs that can be used for fan control.
http://www.msextra.com/doc/ms2extra/MS2 ... ms2options
You need to connect your wide band to the O2 input of your MS.
Then in Tuner Studio under the "tools" dropdown menu select "calibrate AFR"
Then pick your sensor model, or enter relevant #'s to define.
O2 sensor information is in the PDF here starting at page 21
http://www.msextra.com/doc/pdf/MS2V357_Hardware-3.3.pdf
Narrow band sensors cannot be used to tune as they are designed to be a switching type output lean/rich,
their variable output is not calibrated.
A wide band sensor needs a controller, I use Innovate like this
http://www.diyautotune.com/catalog/inno ... p-467.html
cobratone
Post by cobratone »
The spark table looks very low at higher rpm to me, is that correct??
Cobra replica with 383 Chevy, ITB's, MS3X and LS2 coil near plugs
