See this article for how to tune the trim pots.
http://www.diyautotune.com/tech_article ... _index.htm
Hard Start When Cold?
Re: Hard Start When Cold?
Today the car started with no problem. I drove it around the neighborhood. I have a problem where the car wants to "bog down" after starting at a stop sign. In other words, I come to a stop when I release the brake and begin to press on teh accelorator, the car briefly hesitates and acts like it will die before it takes off. I suspect the response time in a setting somewhere needs to be changed. What is that setting? I was unable to attach my log as it was too big so I compressed it and attached it.
It's going lean; looks like the acceleration enrichment needs some fine tuning.
On a probably unrelated note, the battery voltage isn't very stable. Where exactly is the MS grounded?
The MS is grounded to the engine block.Matt Cramer wrote:It's going lean; looks like the acceleration enrichment needs some fine tuning.
