MS2/Extra firmware 3.4.2 released - use this
Postby jsmcortina » Fri Jul 10, 2015 2:13 pm
The current release MS2/Extra firmware for Meqasquirt-2 and Microsquirt is 3.4.2 (superceding 2.1.0d/e, 3.1.1, 3.2.5, 3.3.3, 3.4.0 and 3.4.1)
This should be used for all new installs.
Users of the pre-3.4 development codes are encouraged to upgrade as the dev codes will no longer be supported.
Existing users of older releases may optionally upgrade, but if your install is running well, you may choose to leave it alone.
Download this code from http://www.msextra.com/downloads
Be SURE to read the RELEASE-NOTES.txt file included within the zip.
Find MS2 manuals at http://www.msextra.com/manuals/ms2manuals
Find upgrade notes and installation instructions in the Setting Up manual.
TunerStudio 2.6.x or later is required.
Re: MS2/Extra firmware 3.4.0 released - use this
Postby jsmcortina » Wed Dec 23, 2015 7:37 am
3.4.1 released and supercedes 3.4.0
This is essentially a re-naming of pre-3.4.1 beta 1.
See http://www.msextra.com/forums/viewtopic.php?f=91&t=59917 for details.
Re: MS2/Extra firmware 3.4.1 released - use this
Postby jsmcortina » Sat Apr 09, 2016 4:31 am
9th April 2016: Critical EDIS bug discovered in 3.4.1.
Please revert to 3.4.0 or use pre-3.4.2 beta 2 or later.
Re: MS2/Extra firmware 3.4.2 released - use this
Postby jsmcortina » Thu Apr 21, 2016 4:17 am
3.4.2 released and supercedes 3.4.1
This is essentially a re-naming of pre-3.4.2 beta 2.
See http://www.msextra.com/forums/viewtopic.php?f=91&t=62169 for details.
Users browsing this forum: Google [Bot], gtmdriver and 1 guest
