Mustang mspnp2, msd 6al2, no start- but fires
Blown88GT
Re: Mustang mspnp2, msd 6al2, no start- but fires
Post by Blown88GT »
tonawawa wrote:Now no Spark!
I hooked a 12v test light to the harness plug before the coil, The light would flicker, it is dim, and when I turn the key off it gets really bright before going off.
I changed the ignition switch and that seemed to help the flickering.
Still no spark pulse and the starter is sounding weak to the point that it stops.
I have 12v at the battery terminals. Do I have too weak of a battery ?
Your battery is just about dead at 12.0V. You will need a charger on it full time for all the stuff you're doing.
tonawawa wrote:I am in Eureka Ca. Humboldt County...
Find someone near you to help.
Put the EEC-IV back in to see if it will start.
tonawawa
Post by tonawawa »
It appears my timing light has failed! It would not work on my running 5.0.
Dam piece of s***.
hybrid
Post by hybrid »
tonawawa wrote:It appears my timing light has failed! It would not work on my running 5.0.
Dam piece of s***.
That will definitely make it hard to check your timing.
Do not load someone elses tune and expect it to work for you!
krisr
Post by krisr »
Pop a plug and earth it against the motor with the lead attached, crank and see if you get a spark?
Sydney, Australia
1971 Holden Monaro HQ
tonawawa
Post by tonawawa »
Checked and confirmed a good spark with the stock computer.
Nothing with the Megasquirt!
hybrid
Post by hybrid »
Very strange results, considering limp mode should work even if the MS is broken.
tonawawa
Post by tonawawa »
Megasquirt must be interrupting the signal?
I am sending it back tomorrow.
hybrid
Post by hybrid »
Where did you buy it from?
tonawawa
Post by tonawawa »
E-Bay poweraddersolutions
hybrid
Post by hybrid »
Ok.. no experience with them, so not sure what they are like.
tonawawa
Post by tonawawa »
Its going back to DIY, 1 year warranty. Second one so far.
hybrid
Post by hybrid »
Ahh DIY will sort you out.
tonawawa
Post by tonawawa »
Yes, Hopefully they let me know what they find.
Post by Matt Cramer »
hybrid wrote:Ok.. no experience with them, so not sure what they are like.
Power Adder Solutions is one of our resellers. If you buy an MSPNP or MS3-Pro from them, we would handle warranty support.
hybrid
Post by hybrid »
Figured as much once he said he's returning to you guys.
Blown88GT
Post by Blown88GT »
tonawawa wrote:Checked and confirmed a good spark with the stock computer.
Did it start & run with the stock computer?
tonawawa
Post by tonawawa »
I don't have the correct MAF for it to run on the stock computer. I was getting a nice spark though.
tonawawa
Post by tonawawa »
Still no luck. Sent my MS back to DIY, reflashed the firmware of corrupt data, and went through this twice.
My factory ecu fires the car right up! The timing is confirmed at 10BTDC with a light. My Mustang idles with the factory ecu, lots of white smoke though.
When I switch back to the MSPNP2, its back to the same old problems- crank and no start, and maybe a cough.
I am so bummed on this, I don't think MS can run my car.
Please help.
rickb794
Post by rickb794 »
Of course it can!
Post MSQ?
Another thought is that if your ms is getting data corrupted you have a serious noise problem.
Power or ground or Via the serial (USB adapter with a cord longer than 6")?
Low resistance plug wires non resistor plugs.
Noise filter cap on coil + side.
Have you tried bypassing / removing the MSD?
Blown88GT
Post by Blown88GT »
tonawawa wrote:I don't have the correct MAF for it to run on the stock computer. I was getting a nice spark though.
tonawawa wrote:...
Please help.
1st you said it couldn't run on the factory ECU, then you said it does run on the factory ECU.
White smoke indicates you're burning oil or coolant.
Did you reload your tune after the DIY was returned to you?
Did DIY say what they did?
