Microsquirt and bluetooth module HC-05
Postby olafesq » Thu Feb 04, 2016 2:58 pm
Hi everyone,
I managed to squeeze the bluetooth module inside the microsquirt case and wrote a DIY about it http://www.makestuffblog.com/2016/01/31 ... crosquirt/
Hope you find the DIY useful. Applying it to Megasquirt should be similar.
Cheers,
Olaf
EDIT: moved website to new address http://makestuff.66ghz.com/2016/01/31/a ... crosquirt/
olafesq
Re: Microsquirt and bluetooth module HC-05
Postby chango de naranjito » Fri Feb 05, 2016 8:29 pm
Hey this is good stuff !! I always like learning new stuff. I am lost in the arduino stuff I know nothing about it can you explain that part? and thanks for share this info!!
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
chango de naranjito
Postby dontz125 » Sat Feb 06, 2016 12:27 am
Why use the Arduino? A serial connection to the laptop / PC should work, with the appropriate adapter circuits, obviously.
dontz125
Postby chango de naranjito » Sat Feb 06, 2016 5:41 am
Now I'm more lost. How I do tha? There is a software I can download for that? I really want to do this.
chango de naranjito
Postby olafesq » Sat Feb 06, 2016 6:33 am
dontz125 wrote:Why use the Arduino? A serial connection to the laptop / PC should work, with the appropriate adapter circuits, obviously.
Thats correct. Yet for someone doing it for first time I would still recommend to use Arduino IDE and its serial widow. Less settings to worry about. +Arduino is cheap + a lot of tutorials to get started. (And afterwards you can use Arduino to test your MS on bench, ie. send tooth wheel signals etc.)
And also, Arduino works over USB (has serial converter chip on board), in case one doesn't have serial connection on pc.
olafesq
Postby jsmcortina » Sat Feb 06, 2016 6:42 am
Remind me again what the Arduino is for, aside from "sounding cool" ? You can't tune the Microsquirt with it can you?
Postby chango de naranjito » Sat Feb 06, 2016 8:54 am
Ok I'm ordering mine today.There is anything more to buy? And how I change the baut rate only with my laptop? Thanks, Frank
chango de naranjito
Postby rickb794 » Sat Feb 06, 2016 9:06 am
I think he is using an Ardino to "tune" the BT adapter.
Can't that be done with a shell script?
This is my brain on MegaSquirt!
Use only these manuals http://www.msextra.com/manuals/
Avoid the common pitfalls, Read this before start http://www.msextra.com/forums/viewtopic.php?f=101&t=65757
rickb794
Postby slow_hemi6 » Sat Feb 06, 2016 8:35 pm
I set up my BC04 module with HyperTerminal. It is mostly just changing the BT modules baud rate from what it ships with, to the megasquirts baud rate.
slow_hemi6
Postby olafesq » Sun Feb 07, 2016 7:02 am
Ofc any terminal can be used to send the AT commands (to set baud rate and optionally device name and pairing password). I don't have serial on my laptop so I needed some hardware for USB-serial and I happend to use Arduino for that.
olafesq
Postby chango de naranjito » Sun Feb 07, 2016 1:31 pm
Ok so hyperterminal in windows should work?
chango de naranjito
Postby slow_hemi6 » Sun Feb 07, 2016 7:42 pm
I have this one. It has everything on board as opposed to just the bare module.
slow_hemi6
Postby chango de naranjito » Sun Feb 07, 2016 7:48 pm
The problem with Microsquirts is in the serial connector therw is no 5v and you have to wire that externally.In my case,I had problems with that because I was using a car lighter style power outlet and wasn't always working right and I use msdroid to record the pass in the 1/4 mile with that and the log is incomplete because the 5v come aut or a bad contact in the power outlet
chango de naranjito
Postby slow_hemi6 » Sun Feb 07, 2016 7:50 pm
Yes those lighter sockets are terrible for dropping out power.
slow_hemi6
Postby chango de naranjito » Sun Feb 07, 2016 7:53 pm
I definitely will try this. But im a little lost with the part of changing the baud rate mabe I can find one already with the right one or ask the seller if he can make the change fir me.I will have to wait because the seller says is out until February 13
chango de naranjito
Postby jsmcortina » Mon Feb 08, 2016 2:19 am
chango de naranjito wrote:The problem with Microsquirts is in the serial connector therw is no 5v and you have to wire that externally.
In this case, it would be best to cut off the jack socket and wire in a regular DB9 serial connector - with 5V.
Postby chango de naranjito » Mon Feb 08, 2016 5:48 am
That's a good idea too. Thanks!!
chango de naranjito
Postby dontz125 » Mon Feb 08, 2016 5:49 am
I would suggest that will overload the uS 5v power supply. If you're going with an external unit, try to pick one that can eat 12v.
dontz125
Postby chango de naranjito » Mon Feb 08, 2016 5:54 am
I have the one that Phil sells.
chango de naranjito
Postby grom_e30 » Mon Feb 08, 2016 7:01 am
slow_hemi6 wrote:I have this one. It has everything on board as opposed to just the bare module.
have you got this guy to work as i was looking at them??
grom_e30
Next
Users browsing this forum: CycloneKit and 3 guests
