What coils to use
What coils to use
What coils are people running to do a waste spark system on a 22re mspnp2.
Re: What coils to use
For that I'd try a Ford EDIS4 coil pack. You can drive it directly or use the EDIS4 module to drive the coils. Another option would be any of the LS2 style coils. Really easy to drive and would use the same I/O as driving the EDIS coil packs.
Could I drive the edis coil pack with the mspnp2 instead of using another module. And was wondering if I could use this https://www.diyautotune.com/product/ign ... coil-pack/
The EDIS coil pack and the IGN-4 both require a QuadSpark or equivalent module.
Is there any threads about this on here not sure on how to go about wiring it up besides you need a Hall effect sensor coil pack the module and some how wire those to the mspnp2 extra connector
I did some research last night and found this but the only piece I'm missing to the puzzle is how am I suppose to wire a Hall effect sensor for crank position to the mspnp2 there's no spot for it just an output
The MSPNP for this car is intended to work with a stock VAST ignition. You could, however, wire a Hall effect sensor to the wire that supplied the "NE" signal from the VAST module.
Alright and would I put how many teeth is on the wheel that I'm using and I'm going for crank position not cam position in tuner studio?
So if I put the reluctor wheel on the crank pulley mount the hall effect close to it wire the hall effect to the 2 wires for the distributor, wire up the quad spark and the coils, put the specs in tuner studio it should work
Thanks Matt I really appreciate all your help I think I'm gonna do it and I'll let you know how it goes. If I have any trouble I'll let you know
I modified the 22re dizzy to accept a Mitsubishi CAS and run a 24-1 wheel. I also installed the Dsm igniter and run the Dsm wasted spark coil setup
