Setting fall-back values for sensors
Is there some way of setting the limits of the expected sensor values to trigger fall back, especially for the CLT?
Running current version of Ms2Extra. If I disconnect my (calibrated) CLT sensor to simulate a cable break, the MS calculates -18°C (0°F). This is potentially dangerous for the engine regarding cold advance of the ignition.
As I don't intend to ever have coolant temps that low (motorcycle), I would like to set my lower limit accordingly.
Re: Setting fall-back values for sensors
I wondered the same thing myself. OEM computers have a default value should the sensor either short or open circuit. Would certainly think the MS products would have same.
On a similar question, does the MS throw a code to tell you a sensor has failed? Not all of us run products which display real time sensor data like Shadow Dash.
jim
jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
ms3 has a 'check engine light' function with limp mode strategy's
There is a fall-back implemented I think, as the value is 82°C when no sensor is configured. But it doesn't work for me anymore after calibrating my sensor via the 3 point method. I assume the calculated resistance at that point is so high, that it's indistinguishable from a broken cable to the MS.
My project: Link
You could limit the effect in software settings? No fuelling etc correction outside your temperature range?Dennis_Zx7r wrote:Is there some way of setting the limits of the expected sensor values to trigger fall back, especially for the CLT?
This doesn't sound normal? That out-of-range value is set when you calibrate the sensor through TunerStudio.Dennis_Zx7r wrote:Running current version of Ms2Extra. If I disconnect my (calibrated) CLT sensor to simulate a cable break, the MS calculates -18°C (0°F). This is potentially dangerous for the engine regarding cold advance of the ignition.
Technically, when you perform the 3-point sensor calibration, TunerStudio creates the lookup table that the firmware uses to convert voltage/ADC values into real-world temperatures. It then sends this lookup table to the firmware. When your sensor is unplugged, the ECU will see approx 5V on the input, this should land in a fallback part of the lookup table.
Did you calibrate the sensor through TunerStudio? What 3-point values?
2°C, 5700 ohm
28°C, 1780 ohm
92°C, 225 ohm
BiasResistorValue 2490ohm
28°C, 1780 ohm
92°C, 225 ohm
My project: Link
i have had my microsquirt powered up on the bench in the past without the mat and clt sensor connected and they both show -18jsmcortina wrote: This doesn't sound normal? That out-of-range value is set when you calibrate the sensor through TunerStudio.
I just measured the voltage on the IAT and CLT pins. Both 5v, as expected. IAT falls back to a reasonable value (21°C), CLT falls back to -18°C.
Have removed cold advance in the (not used) lower regions as suggested, so I guess that's a workaround.
The problem definately is the calibrated value! If i use 5429 (2°C) or above, fall back goes to -18°C. At 5428 and below, it falls back to 82°C!
My project: Link
