thanks for helping me learn, I just need to know about ignition in general,slow_hemi6 wrote:I have not seen any manufacturer release a schematic to their coil packs inner workings. You can be sure however that a logic triggered coil pack contains an internal driver.
All coils will have a 12v connection for the coil primary, excluding ballast resistor coil primaries which run on about 9v but start on 12v.
Sounds like Paul who is a VW guy knows all about your coils.
Any potential delay can be compensated for by setting the ignition setting Tooth No1 angle and spark hardware latency settings with a timing light.
Can we tell just by looking if this is a CDI or standard inductive type of coil? How do you know just by looking whether it will work "going high" or "going low". If I found a coil in a junkyard, how could I identify the ones that need to go low to fire? Arn't there some coils with internal drivers that use "going high" also? And if so, couldn't I add a inverter buffer to make it work with the opposite setting (to use it in an application that normally "goes high" and visca versa if I couldn't just flip the control box in the ecu software, like with an OEM computer, to run a different coil )
