It'd certainly streamline tuning and, if it allowed getting rid of the VE table, would free up quite a chunk of scarce RAM.jsmcortina wrote:Andy has been asking me to implement a test code that does this... I haven't got there yet.robs wrote:In other words it means RPM has no bearing on PW. Rather than needing a 2D lookup we could determine PW by a simple 1D lookup (like WUE).
Andy: The graphs do look different and, thinking about it, the high MAP, high RPM values with be stretched out to the right while the high MAP, low RPM values stay over to the left so it will stir the graph up and particularly strengthen the influence of high RPM, high MAP points on the appearance. Just out of interest, do you end up with VE tables that are more or less the one set of values cloned in all columns? That seems to be an outcome you'd expect from this graphical target but I'd have thought things like lean cruise settings and intake/exhaust length harmonics would bring RPM dependent bumps into the table.
Have fun,
Rob.
