Closed Thread
Closed Thread
Thread closed. All sorted. Thank you.
Closed Thread
Thread closed. All sorted now. Thank you.
Re: MS2 v3.57 "Not RPM Synced"
Does the EDIS module spark while cranking?
Re: Closed Thread
At the risk of sounding like a dick, you do realise the next newbie to come along will have no chance to benefit from your experience? If you had a mechanical fault, a procedural error, or something just plain didn't work, you obviously figured it out. Why not share the wisdom?lxwrence wrote:Thread closed. All sorted now. Thank you.
Far more is learned from mistakes than flawless perfection, and someone else's mistakes are far easier on your wallet than your own!
Re: Closed Thread
+1dontz125 wrote:At the risk of sounding like a dick, you do realise the next newbie to come along will have no chance to benefit from your experience? If you had a mechanical fault, a procedural error, or something just plain didn't work, you obviously figured it out. Why not share the wisdom?lxwrence wrote:Thread closed. All sorted now. Thank you.
The search function of any forum like this is priceless.
