microsquirt ford A4LD OD control
Postby techdog1 » Tue Dec 13, 2016 10:09 am
I have several questions about the Microsquirt. Can the Microsquirt be set up to control the TCC and OD solenoids on a ford A4LD transmission? I will be using it for fuel and ignition on a 2.3 turbo. Can I use the outputs on pins 16 ALED and 17 WLED spare relay outputs to do this? Also can the outputs be programmed to provide the output based on TPS and speed, or MAP and speed Inputs? How do I set up the conditions to allow the output control?
R/S
James Short (techdog1)
techdog1
Re: microsquirt ford A4LD OD control
Postby Matt Cramer » Wed Dec 14, 2016 1:00 pm
The main problem with this is that it's very difficult to get a speed signal into a MicroSquirt (unless, of course, you're using its transmission control code version).
Users browsing this forum: Baidu [Spider] and 3 guests
