Need Help With 1jzgte ms2
timedrummer
Post by timedrummer »
Greetings
im seeking some help as to how to wire and startup my 1jzgte
im using ms2 with zeal board
5vpull up circuit to fire the stock igniter
using stock crank pick up and stock cam pickup (rear)
all stock sensors
the car is wired as wasted spark config
1-6 spark a
3-5 spark c
4-2 spark b
im using odds/evens with the injectors
1/3/5 bank 1
2/4/6 bank 2
using 800cc injectors low ohm
i got the engine to crank but not running
rpm sync
im getting spark
thanks really appreciate it
rickb794
Re: Need Help With 1jzgte ms2
Post by rickb794 »
The ini file is used by TS to talk to your MS.
The file you want to post is .msq format. You can find it in your project directory. You will need to do a restore point or rename the file to something other than "current tune" in order to post it.
Have you confirmed timing is OK with a timing light?
timedrummer
greetings,
i will send the file asap.
im not sure of the timing right now however i will confirm it.
i wanted to know the settings to put in tunerstudio
timedrummer
please see attached file
timedrummer
>?? any info?
grom_e30
Post by grom_e30 »
Whats your engine firing order? warm up enrichment settings look wrong should end at 100 when fully warmed up not 166%, your fuel ve table is also quite odd.
timedrummer wrote:>?? any info?
I was waiting to hear what you found with the timing light.
timedrummer
sorry for not sending that info
the timing is all over the place even the lost sync reason is all over the place keeps counting from 1 to 20 upwards
this happen since a tuner came to do his work im just the installer for the megasuirt trying to help my friend i would love some advice would appreciate it
thanks in advance
timedrummer
grom_e30 wrote:Whats your engine firing order? warm up enrichment settings look wrong should end at 100 when fully warmed up not 166%, your fuel ve table is also quite odd.
1-5-3-6-2-4
so i need to start over the settings?
rickb794
Post by rickb794 »
That firing order does not jive with the way you have wired the coils
From your first post -
"the car is wired as wasted spark config
1-6 spark a
3-5 spark c
4-2 spark b"
Looks like you need to swap #5 & #4
This is easier to grasp if you order the spark outputs
1-6 spark a
4-2 spark b
3-5 spark c
then it is easier to see that you have wired 1 4 3 6 2 5
timedrummer wrote:sorry for not sending that info
thanks in advance
OK, you need to fix this before you work on anything else whatsoever. Without a good timing signal, everything else will be wrong. To get started on that, please post a composite log of what is going on; this will let everyone take a close look at the crank / cam signals.
xgrapher
Post by xgrapher »
I've ran atleast 10 1jz/2jz engines both vvti and non-vvti so you can definitely count on me. Firing order should be:
A) cyl 1 and 6
B) cyl 2 and 5
C) cyl 3 and 4
Injectors should also be paired in this fashion.
And use this for the ignition capture settings for the non-vvti:
xgrapher
Post by xgrapher »
Make sure that the cam/crank sensors are wired correctly (check their polarity). And if the above doesn't work then try switching from front to rear cam sensor or vice-versa
timedrummer
greetings
Tuesday i will be at the engine working on it so ill keep you guys posted
thank you
timedrummer
xgrapher wrote:I've ran atleast 10 1jz/2jz engines both vvti and non-vvti so you can definitely count on me. Firing order should be:
A) cyl 1 and 6
B) cyl 2 and 5
C) cyl 3 and 4
i only have 2 injector drivers could i see ur injector set up also the injector page if possible?
timedrummer
thanks in advance
no problem
timedrummer
i will correct this
xgrapher
Post by xgrapher »
Wire 3 injectors to inj1 and another 3 to inj2 it doesn't matter what goes on inj1 and what goes on inj2. Use the untimed injection option
timedrummer
xgrapher wrote:Wire 3 injectors to inj1 and another 3 to inj2 it doesn't matter what goes on inj1 and what goes on inj2. Use the untimed injection option
ok no problem :msq:
