Hello guys, me again XD
I am installing an MS2/extra 3.4.2 and today I managed to install it on my harness, did some test with spark, fan relay, fuel pump everything is fine
Composite logger for some reason is not working, I was able to see the crank signal on tooth logger.
I have a 6/7 subaru crankshaft timing sprocket (right) and on weekend I will get the 36-2-2-2 (left)
Does this log looks fine for a 6/7? Just want to confirm my crank signal is strong and stable, here it is how I managed to gather the tooth log when cranking:
MSQ attached just in case you have any recomentations.
Thank you guys!!
Subaru 6/7 crank wave form
Re: Subaru 6/7 crank wave form
LOL I just need a yes or no answer, if it looks fine or not, seems that my question is very complicated
I don't know anything about subarus but if that tooth log represents the bottom right wheel then the time between teeth should be short, medium, long, repeat. Like your log shows.
