VRIN circuit, no signal at TSEL. What about the U7 OpAmp?
An electronics novice here.
I suppose U7 (OpAmp) recives the adapted VR signal in the 3 pin input. Pin 2 is the another input used to adjust the hysterisis and voltage from the signal.
But U7 not only amplifies the signal right? It converts VR signal into a digital signal, is that correct?
Yesterday I checked the signal in VRIN (correct) and TSEL (no signal), but forgot to check on U7's pin 3. But let's suppose I get a correct signal there (I'll check it this afternoon). Which is the problem? Or is that not a problem?
If R52-R56 pots are wrongly adjusted, U7 should give a signal?
Thanks!
SOLVED THIS, BUT I HAVE MORE PROBLEMS WHILE TRYING TO SYNC VR SIGNAL (see replies)
Thanks!
Last edited by EnricGuardiaSinfreu on Mon Mar 27, 2017 2:01 pm, edited 2 times in total.
Re: VRIN circuit, no signal at TSEL. What about the U7 OpAmp
Thanks Matt, that's exactly what I was looking for
Wow, this is really killing me, guys....
Found that Q22 had a bad solder joint so VR conditioner circuit couldn't work. Okay, my fault, it has sense. Repaired it. Checked with a 9v battery the voltages on U7's pin 1,2 and 3.
Before repairing that, pin 3 always was recieving 4.8v, because Q23 wasn't working, it was useless to use R56 pot. Now I can change the voltage on pin 3, from 4'8v to 0v. Cool. Finally I adjusted it to 3.5v.
Changing the polarity of the 9v battery, simulating AC voltage I could see pin 1 was near 5v with + power and near to 0v with whith ground. This is OK, right?
I was happy, this was going to work, finally I would sync those RPM. Plug everything on the car, TunerStudio, everything OK. Doesn't sync.
Check U7 pins.
-pin 3: didnt scope it,teorically was adjusted at 3.5v
-pin 2 its a 0 to 5v signal.
-pin 1: always 5v
Adjusted R56 all anti-clockwise, nothing, all-clockwise, nothing. I was alone so it was difficult to adjust R56 pot while cranking.
My wheel is a 60-2 (BMW) and at VRIN looks like this:
What I am doing WRONG? Have adjust the potentiometer while cranking?
Also, is there anywhere explained how MS2 interpretates the IRQ-1 signal (pin 1 U7- VROUT). What does really measure, the 5v pulse width?
Thanks so much
Check U7 pins.
-pin 1: always 5v
Thanks so much
If pin 1 is stuck at 5V even if pin 2's signal can go above and below the voltage on pin 3, something is wrong with U7.
Solved this. Problems were two:
1) Due bad soldered joints, Q23 hadn't neither ground nor signal
3) Clockwised R56 pot
2) Swapped wires (ground to positve)
Now works properly.
Now works properly.
