2.3T ford microsquirt help needed
Joe dirt
Post by Joe dirt »
1987 turbo coupe 2.3L
3.4.2 firmware
Microsquirt from diy auto tune
36.1 crank wheel
1.9 escort vr sensor .030 airgap
Ls2 coils
Wasted spark
Batch fire injectors
80lb deka injectors
Gm coolant, 4bar map,iat
Ford tps
I'm attatching my settings below
I can get it to hit and burble but acts out of time (backfire, slow start, etc)
I'm not sure I've got the ignition setup in tuner studio correct can you guys guide me along?
elutionsdesign
Re: 2.3T ford microsquirt help needed
Post by elutionsdesign »
We do better with tune files and datalogs but I suspect your "seems out of time" comment is correct. The magic happens with the tooth #1 angle, read up on that and make certain the value of 85 is close.
Graduate of EFI University.
The Deviant
Post by The Deviant »
Have you actually checked the timing with a timing light? If so, does it look right?
James B.
1985 Merkur XR4Ti Rally Car
MS3 3.57+MS3X+RTCC+Knock
Ford Lima 2.3 Turbo/MSD LS2 COPs/DIYAT Hall Cam Sensor/Electromotive VR Crank Sensor
Nexus 7 Instrumentation with Shadowdash MS
rickb794
Post by rickb794 »
18 skipped pulses? WTF!
set that back to 3.
old guy
Post by old guy »
Why do you have the hei/dis option on.
Also show a diagram of how you have your LS coils wired.
skalor
Post by skalor »
Are you getting sync errors of any kind when cranking? Have you verified timing just while cranking, without fuel?
Dwell setting seems high to me as I have my D585 coils setup somewhere in the 3ms range for nominal dwell.
old guy
Post by old guy »
Set your dwell to standard instead of fixed duty. Then in the box bellow that set your dwell to 3.2 and spark duration to 1.0.
