MS2 AFR TARGET FAIL
MS2 AFR TARGET FAIL
HI, i have fail in the afr target, always is un 14.0. and tune analyze live therefore it does not work well.
thanks
thanks
Re: MS2 AFR TARGET FAIL
When I try to load your MSQ it appears to be empty.
As far as your log goes, jacking the throttle 6-7 times in about 3 seconds makes it a bit difficult to visualize whats going on.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Have you calibrated AFR table?
yes, but in the AFR TABLE 1 , i have target of 12.8 a WOT and 14.7 to idle, but el AFR1 TARGET in tune analyze live is always is 14.0, not change.
You have "don't include AFR target" set?
General settings tab.
That'll do it!rickb794 wrote:You have "don't include AFR target" set?
yes, i change to "incluide AFRtarget". but the problem remains the same.
MS/Extra 3.4.2.
MS/Extra 3.4.2.
After a burn and a power cycle?
Sent from my SM-G900V using Tapatalk
incorporate AFR target does not change what the AFR target is, it changes the fuel calculation such that changing the AFR target table will cause an immediate change in fuel for the corresponding cells rather than "simply" a change in the AFR target for that vector.
Can you screen shot this please? Turn megasquirt on with TS connected, go to fuel settings then click fuel calculations summary and screenshot that please. Also do you have a stimulator?
Your msq is showing EGO control as Disabled.
Cheers Luke
Cheers Luke
this is the problem, with afr target when the engine is run.
I'm surprised but I think it's because EGO control is disabled. The 14.0 value is hard-coded in the MSQ, however it's hard-coded in mine too and my AFR Target works but I always have EGO control turned on. If I don't want EGO control to do anything I set step size to 0.
Make the changes yourself or you can try MSQ attached.
In the MSQ posted previously the EGO is disabled.
The MS has no idea what the exhaust looks like how can it make corrections?
Do you have a wideband installed?
Have you calibrated the sensor? Under the "tools" drop down menu, "Calibrate AFR Table"?
Please use screen captures rather than cell phone pics, to make things readable.
seijirou wrote:I'm surprised but I think it's because EGO control is disabled. The 14.0 value is hard-coded in the MSQ, however it's hard-coded in mine too and my AFR Target works but I always have EGO control turned on. If I don't want EGO control to do anything I set step size to 0.
thanks, work well.
