klde v6 not starting and backfiring
jimmyhotrod
Re: klde v6 not starting and backfiring
Post by jimmyhotrod »
DaveEFI wrote:I generally make up a timing scale or disc and attach to the crank pulley. Only needs to be temporary - printed out at home and glued on. Mark a true mechanical TDC and use a timing light to check your spark is actually happening where you think it is.
Hi dave, I did that, I actually made a sticker so it's on my pulley. I then used a dti to find tdc then adjusted my wire pointer to 0 deg.
Wheel on the left is a stock wheel with the outer pulley machined off, wheel on the right is the custom pulley.Image
Sent from my SM-G935F using Tapatalk
jimmyhotrod
Here's where I got the trigger from:
http://megasquirt.free.fr/sources/MS/ma ... 2/36-1.htm
I just scaled it to replicate the same diameter as the stock trigger wheel.
sanjay18
Post by sanjay18 »
Any update
WillExoIX
Post by WillExoIX »
cactus wrote:Certainly not vehicle specific, but I've never seen any engine with a 123456 firing order as you note in your first post. If you are firing like that, I would think that may cause some trouble?
Most all GM 60*v6 engines fire 123456.
Thats a thing you know now.
Megasquirt 2 V3.0 Running Msextra 3.4.2. in a 1989 Camaro RS .48AR/60mm Turbo 3.4L/700R4
Boost control, Fan control, Stepper IAC, Launch/Antilag, Working on the GMDIS, and Methanol injection
