So I've got a microsquirt module and I am trying to go with sequential fuel and spark on a 4cyl engine.
For ignition I'll be using ign1 to 330ohm resistor to bip 373 to my coil 1
Ign2 to 330ohm resistor to bip 373 to my coil 2
for cyl 3 I'll be running 100ohm resistor from vref to aled to 330ohm resistor to bip 373 to coil 3 and same for coil 4, Is that correct?
For fuel inj1 and inj2 is simple.
For cyl 3 and cyl 4 I'll be using pt6 and pt7 and identical ignition drivers as my inj1 and inj2, my question is do I run 1k resistor from pt6 to the injector driver, and run a 100k pull down resistor as well on both pt7 and pt6?
Did I get it all correct?
Thanks.
microsquirt module
