thermistor calibratoin values sr20det nissan
Hello so I just uploaded my firmware to the 3.4.2. I now need to recalibrate all of my sensors. I have a sr20det factory coolant temp sensor and a gm IAT sensor which I purchased from DIY. I have been searching all morning and cannot find the resistance values that I need for the sr20 coolant temp sensor and I think I can just use the default GM settings in tunerstudios for the GM IAT
Re: thermistor calibratoin values sr20det nissan
Should be fine, are you getting sane temp indications in TS?
You can tell in the morning, see if both indicate the same temp. (ambient)
well the problem is after the firmware update my calibrations where lost. now I cant find the values I need to enter for the coolant temp sensor for it to read accurately
DO the DIY instructions include this info?
https://www.google.com/webhp#q=nissan+s ... sor+values
TEMPERATURE: 68°F (20°C)
Resistance: 2.1 - 2.7 K ohms
TEMPERATURE: 94°F (90°C)
Resistance: .24 - 0.26 K ohms
TEMPERATURE: 230°F (110°C)
Resistance: 0.14 - 0.15 K ohms
