EJ20G Basics
ajj686
EJ20G Basics
Post by ajj686 »
Hello all,
I currently have a 2000 2.5rs which I have swapped in an EJ20G Version 2 motor. I have the motor, engine harness, and intercooler as well as all of the stock 2.5rs parts (if needed). I would like to use Microsquirt to run the motor. Ultimately, I am going with Microsquirt to have tune-ability and avoid spending $1,200 on a rare EJ20G bulkhead harness. I am a novice, but a quick learner. I have received the list of necessary parts below. I will continue to do my research, but any help is greatly appreciated!!
A few quick questions:
1) I have all of the ignition setup that comes mounted on the motor. I believe that this motor uses a COP setup with an ignitor mounted in the engine bay....I do not have said ignitor. Is it best to convert to a newer WRX coil setup or track down an ignitor?
2) Will I need to purchase new sensors or can I use the stock Subaru sensor for the IAT and CLTIAT(with the exception on the MAP sensor and wideband)
The List
$339.00 MicroSqrt3: Assembled ECU (includes short harness & tuning cable)
$64.00 GM3bar-map: MAP sensor
$11.50 GM3bar_piggy: Pigtail connector for MAP sensor
$17.75 CLTIATwPiggy: Coolant / Oil temperature sensor
$22.25 IATwPiggy: Intake Air Temperature Sensor
$9.00 38NPT-Bung_A: Aluminum bung for IAT sensor (Also available in stainless steel)
grom_e30
Re: EJ20G Basics
Post by grom_e30 »
you can use the stock clt and iat if you can find out the calibration data for them, or you can measure this with a ohm meter and a thermometer.
the microsquirt can only control logic level coils so you would need an external igniter or a smart coil that takes a 5v signal to fire it.
ajj686
Re: EJ20G Basics
Post by ajj686 »
Great and what will control my oil pressure sending unit? I apologize if these are basuc questions.
rickb794
Re: EJ20G Basics
Post by rickb794 »
MS does not need oil pressure info.
Or are you talking VVT?
ajj686
Re: EJ20G Basics
Post by ajj686 »
The Ej20G has an oil pressure sending unit, but because the megasquirt doesn't need it I dont have to worry about that correct?
rickb794
Re: EJ20G Basics
Post by rickb794 »
Not for the MS. You probably should have something for the driver
Sublimejoe
Re: EJ20G Basics
Post by Sublimejoe »
First time poster. Joined to look for more reasons that I should go microsquirt on my ej20k.
How are you doing on this?
