No injector pulse only once when key cycles
Vehicle is a 1974 Toyota Celica 20r high compression pistons
ms2 assembled by diy auto tune
edis4-coil and ignition module- bmw 325 crank sensor
22r edis intake manifold
210cc injectors
gm clt and air temp
toyota tps
inj wired 1&4 -3&2
coil wired as stated on the coil pack it self
1 4
plug
2 3
oxygen sensor is disabled at moment due to exhaust needs to be finished headers as of now.
20R firing order 1432
I am also using the tune for a 22r start up base map from diy auto tune
Vehicle backfires ran for a few seconds very rough now after tinkering will not run for long and seems off timing/ advanced.
210cc injectors
gm clt and air temp
toyota tps
inj wired 1&4 -3&2
1 4
plug
2 3
Re: No injector pulse only once when key cycles
Probably timing, get a timing light in there and verify things per the manual.
Graduate of EFI University.
It ended up being the laptop had a virus and was screwing up tunerstudios settings. I reset the firmware and used my destop computer with extended com port and once everything was reset it started perfectly.
What virus?
Windows.rickb794 wrote:What virus?
Yes... windows is a virus
4wheel drive 454 vortec on ms2 w/gpio for 4l80e Trans control
Are you sure it is a virus and not just corrupted firmware?Toyota20R wrote:It ended up being the laptop had a virus and was screwing up tunerstudios settings. I reset the firmware and used my destop computer with extended com port and once everything was reset it started perfectly.
My very first install drove me crazy for about two weeks, it turned out the firmware was corrupted.
I reinstalled the same firmware and everything worked fine after that, just a thought.
David
