Sync losses during warm up...
milesinfront
Post by milesinfront »
Recently rectified an issue with my brother's car where there was no spark when the MS box went under about 18 deg c. Fixed that issue by switching over to dual Haltech/HuCO igniter modules.
So now the car starts and runs beautifully in our relatively mild Australian winter!
BUT
When driving during the warm up phase it will lose sync once or twice (with the big tell tale cough) for no apparent reason. Once up to temperature there are no sync losses and the car runs solid.
Any ideas???
Tried pre-heating the MS box with a hair dryer (that always solved the previous problem) but it didn't help...
Build info is here:- http://www.msruns.com/viewtopic.php?t=22669
MSQ here:- https://www.dropbox.com/s/m51wtqeq5x7sg ... e.msq?dl=0
Log here:- https://www.dropbox.com/s/07ri4choevbb8 ... 8.msl?dl=0
-1988 325is BMW M52B28 - > MS2 Extra n Spark (60-2 Wheel, Wasted COP, Single VANOS)
-2004 Opel Corsa C / Holden Barina Z18XE - > MS1 Extra n Spark (60-2 Wheel, Wasted COP)
-1976 Triumph Dolomite Sprint Race Car -> MS1 n 'EDIS'd
-1984 C1 2.3 Alpina -> MS2 Extra n Spark (60-2 Wheel)
milesinfront
Re: Sync losses during warm up...
:yeah!: :yeah!: :yeah!: just noticed this build is 9 years old! :yeah!: :yeah!: :yeah!:
rickb794
Post by rickb794 »
No need to rush into anything.....
milesinfront
as in running for 9 years...
milesinfront
Not getting much love trying to solve this problem... :(
Am I asking in the right place, or is there another section I should have posted in.
Been a long time since I was active in the MS forums.
