Injector doesnt close?
Hello everyone,
maybe Im posting on the wrong place but I have an issue with my corolla 4AGE engine.
I have some issues with injecting... cylinders #3 & #4 are not firing as they should and spark plugs are black.
I've changed distributor arm and distributor cap. Checked injectors. All good
Compression on all 4 cylinders are great (~190 PSI)
Compression test on all 4 cylinders is the same
Spark plugs on cylinders #3 & #4 are like this on #1 & #2 are normal.
Tried:
- replaced injectors
- check old injectors with Tunerstudio INJ test tool, all injectors are "clicking"
Is it possible that DIYPNP has some problems?
Maybe I've forgot something to write.
Tried:
Re: Injector doesnt close?
If you swap the injector wiring around, does the problem follow the injectors or the wires?
@jsmcortina
when I switch injector wiring from #2 to #3, #3 cylinder works #2 doesnt
I don't know a lot about the DIYPNP. Best to discuss with your supplier.
I have a DIYPNP, some of it is the same as yours.wewerica wrote:...
Tried:
It's not injectors, it's ignition. Plugs are not firing.
Double check the docs for yours, see section DIYPNP Jumper Configuration
https://www.diyautotune.com/support/tec ... a-corolla/
Car was running for one year without any issues and one day it just died
You didn't think this was important enough to mention in the 1st post?wewerica wrote:Car was running for one year without any issues and one day it just died ...
Bad connection.wewerica wrote:@jsmcortina
I forgot it sorryBlown88GT wrote:You didn't think this was important enough to mention in the 1st post?wewerica wrote:Car was running for one year without any issues and one day it just died ...
I was driving it one day uphill and when I got to the traffic light car was running like a crap
I've changed distributor arm, cap and spark plugs but no luck. Tried with cables too.Blown88GT wrote:Bad connection.wewerica wrote:@jsmcortina
Checked the injectors all working as they should.
Checked connection between injector connector and ecu connector, its fine.
Get inline spark tester.
Why do I need this?Blown88GT wrote:Get inline spark tester.
Spark is ok on cylinder #3 when I switch connector from injector #2 to #3. Cylinder #3 works like this.
You stated:
How did you determine that spark is okay without using a spark tester?
If the injectors are functioning, then it must be the spark plug that's not.wewerica wrote:...check old injectors with Tunerstudio INJ test tool, all injectors are "clicking"
...Spark is ok on cylinder #3 when I switch connector from injector #2 to #3...
switched places for injector connector #2 and #3 and got injector/cylinder #3 to workBlown88GT wrote:You stated:If the injectors are functioning, then it must be the spark plug that's not.wewerica wrote:...check old injectors with Tunerstudio INJ test tool, all injectors are "clicking"
are you set for sequential injection? or batch injection? also
@grom batch injection
will post tomorrow sorry
just out of curiosity are the 2 problem injectors on the same injector channel?
Problem are injectors #3 & #4, they are on one channel.
Just for test: I've switched places connectors on inj #2 & #3. And got cylinder#3 to work
Todays datalog and msq
Not sure how ignition timing is set, I've removed distributer so I will have to check when I get car to work.
it sounds like it may be a hardware issue on the injector driver
grom_e30 wrote:it sounds like it may be a hardware issue on the injector driver
Is this all the hardware for injector driver?
pretty much. but do check from the main board that the microsquirt module plugs in to
