2109cc Boosted Bug won't start...
MegasquirtBug
Post by MegasquirtBug »
Hi to all,
Recently I upgraded my 1970 Beetle from 1776cc to 2109. The car has NEW everything except for the engine block. Anyway, The car has been down since 8/16. I started the car on 6/17 for the cam break-in process for 20 mins or so at 2000 rpms more or less with no problems at all. Two days later a friend came down to my house to help me with some stuff and I turn on the car for aprox. 10 mins. and it die instantly.
The battery was have dead after 3 charges, so I went to buy a new one since the test in Advance Auto revealed "dead cells". So, It's not the battery :D .
For now I checked for vac leaks in the manifolds and it was ok, did the spark test on MS2 and side A and B make spark. The injectors work since one side was leaking after intake install #2.
Today, I moved the crank sensor a bit outward from the wheel since it was almost touching it. Tried to crank and NADA.
I made a log while cranking.
Thank you for your time...If anything else is needed please post.
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark with MSD coilpack, dual table, launch control and 3.88 tranny. Anyway, runs great can't be more reliable than this. All done by me...:) t03 running 48lb. Injectors, Intercooler, W/M injection at 15psi for now.
hybrid
Re: 2109cc Boosted Bug won't start...
Post by hybrid »
MSQ might help too.
Do not load someone elses tune and expect it to work for you!
MegasquirtBug
I knew one was missing.
I just opened the MS2 and played with the POTS. I got a backfire once.
hybrid
Post by hybrid »
What kind of trigger setup is it?
Edit: configured as 36-1
Your trigger log definitely doesn't seem to be reflecting that setup.
MegasquirtBug
Hybrid,
Thanks for looking.
It's configured as wasted spark with a 36-1 trigger wheel.
It was running great until 8/16. I didn't touch anything then it suddenly died.
hybrid
Post by hybrid »
First port of call would be the crank trigger I think.
The trigger log is definitely not showing a 36-1 wheel.
hybrid
Post by hybrid »
Can you do just a tooth log instead of a composite log?
MegasquirtBug
Ok,
I'll do one tomorrow when I get back from work.
Thanks,
rickb794
Post by rickb794 »
Suppression wires (low resistance wires are not suppression wires) and resistor plugs
MegasquirtBug
rickb794 wrote:Suppression wires (low resistance wires are not suppression wires) and resistor plugs
The wires came with the coilpack. They are new and the plugs are a resistor type,
rickb794
Post by rickb794 »
Spiral wound low resistance wires are not suppression wires.
Google "spiral wound plug wires problems"
The first result is "Truth About Ignition Wire Conductors"
https://www.magnecor.com/magnecor1/truth.htm
There are a lot more results worthy of reading.
MegasquirtBug
hybrid wrote:Can you do just a tooth log instead of a composite log?
Hybrid,
I just made the tooth logs. I have a VR sensor on the car.
2017-07-03_tooth.csv
2017-07-03_toothII.csv
