1988 tbi 454
Re: 1988 tbi 454
i used 2 differant distributors and same result
Re: 1988 tbi 454
You've got some weird stuff going on with PW in those logs! Can you post the MSQ those were made with?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Re: 1988 tbi 454
You mean the tune file ?
Re: 1988 tbi 454
this is how i could get it to idle for a few minutes at best
Re: 1988 tbi 454
It appears that you are running B&G code! Are you aware that they have their own, separate forum?
I'm thinking that it might be better (in terms of help/support) for you to switch to Extra code.
Re: 1988 tbi 454
Gotten no help from that forum either i dont know how to update it or if i evan can its a old microsquirt
Re: 1988 tbi 454
It's still a MicroSquirt no matter how old it is! All the info you need to load The latest code is covered in the manual at the top of this page.cj599 wrote:Gotten no help from that forum either i dont know how to update it or if i evan can its a old microsquirt
As I said, you are likely to get more help on this forum if you are running Extra code...............
Re: 1988 tbi 454
Firmware is installed i guess i get to start from scratch i changed the dizzy to a new tbi dizzy with remote coil and i need to wire it up and maybe beg for a start up tune
Re: 1988 tbi 454
I was so nervous i know its a old squirt and ive never updated one this is all new to me
Re: 1988 tbi 454
is this the right way to wire up my distributor ?
Re: 1988 tbi 454
I took a stab at creating an MSQ for you. USE AT YOUR OWN RISK.
I looked up the HP/TQ specs for a stock 1988 454 (230 hp @ 3600, 385 tq @ 1600) and used the AFR and VE table generators. I took the spark map from my small-block and pulled 10 degrees from the entire map since I have a performance engine and you have a truck motor. I went on the basis of 80lb/hr injectors that are common to the 454 TBI.** I use the same distributor. Yes, your wiring diagram looks correct. However, you may want to hook the Bypass wire (magenta/purple in your diagram) to TPS VREF to make sure it gets a signal.
I didn't know where to select Microsquirt -- I have an MS2. You might be able to use this, or maybe not. Hopefully one of the others can chime in here. If the other experienced members think this is a bad idea, I will delete it.
**80lb/hr is at 11psi of fuel pressure. Get a gauge and measure it. If you don't have one, you can probably get one from the Autozone tool loaner program. These are large injectors and 1 psi of fuel pressure will make a measurable difference.
-Dave
-Dave
Re: 1988 tbi 454
Im gona add a fuel pressure sensor to a spare port and i really appreciate the help so much i wont try the msq until i get everything sorted out
Re: 1988 tbi 454
also the engine has a intake and a small comp cam with fast bleed lifters so at idle the stock ecm tune it would idle decent but as long as i can her to fire that will be awesome i still need to buy a wideband an a few other things and this set up is temporary until i buy heads a good mpfi intake and tb for my 489 this is kinda of a proof of concept for me to find out if im capable of making this set up run its in a a 1986 camaro with a th400 i have 1-7/8 primary shorty headers also
Re: 1988 tbi 454
should i use this diagram and use the same letter on the module to make my connections
Re: 1988 tbi 454
It depends on which diagram you should use, since you still haven't confirmed which dizzy you have.
Again posting pictures of YOUR engine and parts used will help us to help you.
Pictures of the module inside the dizzy, and the dizzy itself will be good to help us direct you on how you need to wire it up.
BTW, the way I stated does indeed work, I've done it. ;)
Tha Daily: 2005 Chevy Blazer
Re: 1988 tbi 454
Its a small cap remote coil hei what came stock on the 88 454
Re: 1988 tbi 454
What is the impedance of your injectors?
If they are low impedance (which Im pretty sure they are) how have you made them compatible with a microsquirt?
Re: 1988 tbi 454
How do i do that ?
Re: 1988 tbi 454
cj599 wrote:is this the right way to wire up my distributor ?
This is exactly how its wired and it will not show a rpm no matter how i change the ignition settings i dont what to do
