1988 tbi 454
1988 tbi 454
i have a basically stock 1988 454 tbi in my camaro and i am confused on the injector characteristics in tuner studio the injectors i have are early 454 and i am running a microsquirt v2.0 bored tuner studio says v2.89. also i was having some issues with getting a good rpm signal i am using the option- method wired to a accell hei. where you supply 12v to one wire i believe it was opt+ i think i cant remember and i had it working great and accidentally loaded a tune where my ignition settings are messed up anyone able to help? a base map to get me goin would be awesome but probably dosnt exist thanks for the help
Re: 1988 tbi 454
Most installs use the "vrin", not "optoin", but tell us more about the dizzy and how you want to use it. Is that Accel product literally a clone of GM's HEI (which, HEI-7 or 8?)? Do you want to fire the coil using the HEI module, or do all control/firing from MS? If you want to move past the HEI module, what kind of sensor is in the dizzy itself, VR, or Hall?
Post your MSQ and an MSL.
Don't worry about the mismatch between the PCB version and TS version, they have no correlation.
Do be sure to verify spark timing while cranking, before trying to start the engine.
PS: This kind of thread should really go on the "Assembly" or "General Support" forum; you might get more views and help there.
Re: 1988 tbi 454
its a clone of the 80s large cap hei and im doin fuel only i had it working g reat as far as rpm goes a while back
Re: 1988 tbi 454
I know nothing about MicroSquirt, but I am curious....... Why do you have your ignition set to EDIS if you are running HEI?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Re: 1988 tbi 454
thats the only way it would show a rpm
Re: 1988 tbi 454
well i got it to reed the rpm no set on edis but it seems sporatic like i have the injector stuff wrong like the microsquirt is being over loaded maybe i dont know what the dead time or the other charectoristics should be im lost
Re: 1988 tbi 454
And exactly did you accomplish that?cj599 wrote:well i got it to reed the rpm no set on edis
FWIW, over the years I have run EDIS, HEI (7 pin) and most recently, toothed wheel (36-1).
Initially I had some issues with HEI but those cleared right up when I switched inputs from Opto to VR.
Re: 1988 tbi 454
Im not exactly sure i switched the ignition settings back and it started working but its kinda off and on when it wants to show rpm i think it has to do with the injector settings but i dont know what they should be
Re: 1988 tbi 454
I seriously doubt that your 'injector settings' will have any effect on whether your're seeing an RPM indication or not!
Can you post a log of an attempted start?
Re: 1988 tbi 454
i will as soon as i can the reason i say that is because some times the microsquirt would power off and back on when i make the ve table too ritch
Re: 1988 tbi 454
Ah, a whole new symptom! The VE values should have no effect on power to the ECU. There is likely a problem with how this install is wired.
Re: 1988 tbi 454
So, it's a large cap, HEI dizzy with mechanical and vacuum advance?
If so, look at using the coil negative connection input wiring and settings for an RPM input into the uS. Connect to the tach terminal on the cap.
If it's a 7 pin version that uses computer control the connections and setting will be different.
Tha Daily: 2005 Chevy Blazer
Re: 1988 tbi 454
Ditto!billr wrote:Ah, a whole new symptom! The VE values should have no effect on power to the ECU. There is likely a problem with how this install is wired.
Make that Mega Dittos!!!
Re: 1988 tbi 454
Not a issue with wiring an that is how i have it connect to the distributor with the fly back method and the opt- wire it would never work like you stated tryed it many timesSix_Shooter wrote:So, it's a large cap, HEI dizzy with mechanical and vacuum advance?
Re: 1988 tbi 454
I have 12v going to injector 1 and 2 and i have them fused then i have one on 1 bank and injector 2 on the other bank seems to me like its being over loaded
Re: 1988 tbi 454
I think it might be a noise issue i seen it just to like 4k rpm while cranking once some times its will run for 15 minutes with out a issue also i used factory metripack and weather pack connections with the right crimp tool im very good with wiring
Re: 1988 tbi 454
Pretty sure if i new the settings for the injectors i could cross that off the list and would make settin this up that much easier but i guess its info no ones willing to help with thanks alot ill probably just go back to a carb this has been a issue with this for goin on 3 years and im tired of dealing with people on forums not helping and just saying read the manual or its the wiring etc or sugesting its always something its not no wonder holley and haltech have more customers
Re: 1988 tbi 454
Okay, I took several deep breaths and will try to keep this thread meaningful...
The "injector characteristics" you have set seem good enough to get the engine started. I can't help much more on those because I am fairly unfamiliar with the Microsquirt and its TS menus/settings. It's not that I won't try to help you, just that I wont' try to give BS when I don't know. However, I am fairly certain that nothing you do with the injectors or their settings should drop power to any type ECU and cause it to reboot or lose com. You have to be willing to consider that you have a "wiring problem" and be willing to investigate/eliminate that possibility or we will be crippled in our efforts to help you. I can suggest some ways to investigate if you are willing.
"Large cap HEI" doesn't tell me much; especially since it isn't a GM dizzy. I could put any number of things, even contact points and a capacitor, under one of those caps. At this point I'm not even clear if it is a 7-pin or 8-pin GM module, or even one of those at all. How about pictures and P/N of the dizzy you are trying to connect to. Like others, using "EDIS" doesn't make sense to me, but I may be wrong. There is no use me trying to learn more about this MicroS-to-HEI interface, to help you, if I don't even know what you actually have.
Posting sketches of how you have things wired may also help. They don't have to be real pretty, but be sure to show all switches, fuses, relays, connectors, etc. and indicate size of wiring. Indicate where wiring is shielded and/or twisted.
Re: 1988 tbi 454
I am not breathing as deeply as Bill............ How many times does it need to be said?billr wrote:However, I am fairly certain that nothing you do with the injectors or their settings should drop power to any type ECU.............
There is no one here who is not willing to help you!!
I don't think anyone is questioning the quality of your work or parts! But, clearly there is an issue aside from any settings in your MS box!
EDIT: Could you please post your most recent tune and a log from that tune?
Re: 1988 tbi 454
I will make a log as soon as i can
