1988 tbi 454
cj599
Re: 1988 tbi 454
Post by cj599 »
This is my distributor and the plugs are getting fire it will run with a squirt of gas
ChevelleFan
Re: 1988 tbi 454
Post by ChevelleFan »
I use that same distributor. On the 4-pin plug, from left to right:
Ground / Bypass / Reference / Advance (I believe the module is labeled G B R E)
That third wire, R, should go to tach-in on the microsquirt.
If that's how you have it wired it doesn't work, get your module tested or try a different module.
-Dave
cj599
Re: 1988 tbi 454
Post by cj599 »
Ill try tack in the diagram shows another wire their
cj599
Re: 1988 tbi 454
Post by cj599 »
My microsquirt harness only has a tach out not a tachin wire i tryed the vr- and vr+ also the option- + nothing seams to work
kjones6039
Re: 1988 tbi 454
Post by kjones6039 »
cj599 wrote:How do i do that ?
Measure the resistance of the injector (unplugged) with an ohm meter.
In my experience, most GM tbi injectors are low impedance.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
ChevelleFan
Re: 1988 tbi 454
cj599 wrote:My microsquirt harness only has a tach out not a tachin wire i tryed the vr- and vr+ also the option- + nothing seams to work
I'd try using HEI module R pin --> VR+
-Dave
cj599
Re: 1988 tbi 454
Post by cj599 »
3
-Dave
tryed it still nothing
ChevelleFan
Re: 1988 tbi 454
3
-Dave
Try hooking it to OptIn+ (pin 30)
-Dave
cj599
Re: 1988 tbi 454
Post by cj599 »
i tryed all 4 possible wires i did notice if i start data logging it will show some rpm for a split second when i first start cranking
ChevelleFan
Re: 1988 tbi 454
Your battery voltage is going very low while cranking -- 8-9v. Charge your battery.
-Dave
cj599
Re: 1988 tbi 454
Post by cj599 »
i tryed a 800 cranking amp battery too that was fulley charged and it seams to go pretty low with that one too
ChevelleFan
Re: 1988 tbi 454
If MS isn't getting at least 10 volts, not much we can do until you get that sorted out. No juice = no run. Maybe you need to wire the source power differently, I dunno. But if it drops to 8-9v when cranking, that needs to be addressed.
I looked at a couple of my own datalogs, and I see it dropping to 10.8-11 on a couple starts to give you an idea of what works.
-Dave
rickb794
Re: 1988 tbi 454
Post by rickb794 »
If a v2 Microsquirt does not have P&H drivers, the low impedance injector issue needs to be addressed after the voltage issue.
Or will this not be an issue with a single injector on each channel?
I tried one with an MS2 years ago and wound up switching to TPI after much head banging.
There are reasons why the OEM's no longer use TBI.....
cj599
Re: 1988 tbi 454
Post by cj599 »
I will be goin mpfi soon but just had a kid so i would like to get it runing im gona get a new battery and a high torque starter and see if that cures the voltage drop issue
cj599
Re: 1988 tbi 454
Post by cj599 »
I do have 1 injector on each channel
rickb794
Re: 1988 tbi 454
Post by rickb794 »
